Old 03-10-2003, 07:16 AM   #1
gmcnorton
gmcnorton's Avatar
tilt column
hey guys/gals
i have a couple of questions,just replaced the tilt column in the blazer today. i need the pointer for the indicator does any of the board member have a new or really nice one for sale? also i need a new bowl for the one i took out {the part that the shift lever attaches to with the pin} the pin was wore and the shift handle was sloppy and ruined the bowl. {the one i took out is also a tilt}
last thing is i need the facorty type attaching hardware for a 72 blazer grille. the little plastic clips that hold the center egg crate grille into the outer. i'm taking out the billet grille that was in the truck it's in excellant condition, just like the factory look better. if any one has the parts i need for the column and the grille hardware i'd be willing to trade also. thanks, kevin
this is the grille i'm removing
70 GMC SHORT STEP , 71 BLAZER ,72 JIMMY,72 BLAZER, JUST NEED THAT SUBURBAN NOW......WANTING MORE
gmcnorton is offline   Reply With Quote
Old 03-10-2003, 07:17 AM   #2
gmcnorton
gmcnorton's Avatar
grille
sorry hard to resive picture and still look good, it make grill look funny.
Old 03-10-2003, 07:53 AM   #3
JimKshortstep4x4
Talking
GMCNorton,
The indicator and grill clips should still be available new from the parts vendors. On your shift "bowl", that is going to be a tuffy!
Don't throw your old one away as someone could use it to fill
for use on a floor shift setup. The shift bezel used to be available
new until a few years ago, so someone may have a new one around.
Good luck!
Jim
