Old 01-05-2011, 05:44 PM   #1
hick
Long Horn Frames. One Piece Or Sectioned?
I am currently shopping for a project vehicle and I have come to like the Long Horn trucks. I understand that they stretched the bed by welding another one to it, but does any one know how they did the frame?
I am looking at one about 500 miles away and the guy there is useless, he won't crawl under and look.
The goal is to the build a work truck, fifth wheel and all, so I don't want a sectioned frame even though i would like to box it.
Did the long horns have a one piece or did chevy section them?
hick is offline   Reply With Quote
Old 01-05-2011, 05:56 PM   #2
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: Long Horn Frames. One Piece Or Sectioned?
The Longhorn used the 133" wb chassis from the 1 ton trucks..so no they did not section the frame, its all 1 piece.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 01-05-2011, 06:14 PM   #3
hick
Alright, thank you
Now that raises another question. If the Long Horn was considered a 3/4 and used the 1 ton frame... How did a regular 3/4 ton 1 one ton different? was one cab bigger then the other?
Old 01-05-2011, 07:16 PM   #4
john
member #16
john's Avatar
heavier suspension on the one ton. There were also one ton longhorns.
john is offline   Reply With Quote
Old 01-05-2011, 07:53 PM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The Longhorns have the heavier frame, 1 ton, because of their camper chassis that they were built to haul. The 3/4 ton Longhorns have lighter rated leaf springs and coil springs, but every thing else is the same. To tell the difference in a Longhorn frame and the regular 3/4 ton pick up frame is pretty simple. Look under the cab area and you will notice that on a Longhorn the frame is taller than a standard 3/4 ton. If I remember correctly it is about 1 1/2" taller than the 3/4 ton standard pick ups. I also think the frame is a little thicker as well, but can't remember on that fact for sure.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-05-2011, 08:13 PM   #6
hick
All makes sense but some thing still isn't clicking in my head.
They added 6 inches into the bed and used the one ton frame. The same one ton frame used in non long horn trucks, if i understand it correctly
If they didn't stretch the frame, just added sheet metal where was this 6 inches hiding on the one ton frame?
Old 01-05-2011, 08:24 PM   #7
4x4toy
I think they used 133" 1 ton cab and chassis trucks, then modified a bed to fit.
If the truck you are looking at is a LongHorn, I am jealous, I love those trucks.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 01-05-2011, 08:26 PM   #8
hick
OH, the cab and chassis frames... NOW it makes sense.
Thank you.
Yes it is a long horn. I want/need a long box. I figure if i can get another 6 inches, might as well...
Old 01-05-2011, 08:34 PM   #9
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
I just got home from looking at a local 72 longhorn. Way too rusty for $1500. The frame is definitely very large and strong on these. In addition to chassis cabs, I am pretty sure a one ton with a long stepside bed also used this same frame. 133" wheelbase.
Even if the frame were sectioned, I wouldn't worry about it. The 01 and up 2500hd's and 3500's have a sectioned frame and they tow up to 16,000 lbs!! Its all in design details and not just the fact that it is a composite frame.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 01-05-2011, 08:37 PM   #10
hick
I am big supporter of overkill . Should this project ever see the light of day, thats going to be its name haha.
Old 01-05-2011, 09:02 PM   #11
Dieselwrencher
This is one thing I love about my Longhorn is the huge frame!
Ryan
