Old 03-04-2002, 03:40 AM   #1
peteyb
Question Idiots to gauges?
I've got a '73 pickup with idiot lights and I'm thinking of swapping out to a gauges dash. Will the current senders and wiring harness do the trick or do I need to also look at scoring a harness and collection of senders? Thanks.
peteyb is offline   Reply With Quote
Old 03-04-2002, 03:45 AM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Lightbulb
If you go with a aftermarket set of gauges then they will have the sending units with it. Also you can just tie into the existing ones. I am going to upgrade mine (have aftermarket now) to all Autometer like this here. http://www.73-87.com/photos/gpics.htm He also has a great article on how he did it. He opted for a new wire harness but is not necessary. The senders in the pack that I got attach to where the temp sender is and the oil pressure in the back of the block top side behind the distributor. One note is to use a copper line instead of the plastic line in the oil pressure line.
BRANDON
1979 CHEVROLET BONANZA BIG10
350 GM Crate Engine ZZ4,1406 Edelbrock, 1 5/8" Heddman Headers
2 1/2" Dual Exhaust with X pipe and Flowmaster 40 Series Mufflers,350 Turbo Transmission,3.07 Gears
My website for the truck.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-04-2002, 03:50 AM   #3
peteyb
Post
So if I'm yanking a dash out of a junkyard (assuming they work), all I'll have to do is swap the dash? All current senders and wiring will suffice?
Old 03-04-2002, 05:23 AM   #4
79BIG10
79BIG10's Avatar
Post
Not for sure but I know that the wire harness should be the same. Just make sure to get the same style gauges that you have now in that they're the same year models otherwise the rear bezel (or dash as you called it) will be different in where the attach to the speedometer. Also make sure that your fuel and if you have a tach are in the same placement as the new one. Otherwise you will need to change out your wire harness then.
But I have to ask why get "junk" gauges when you can get new ones that will work and more accurate?
Old 03-04-2002, 11:30 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Talking
Ditch the factory guages.
Get something that looks better
More recent pictures
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
[This message has been edited by gchemist (edited March 04, 2002).]
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-06-2002, 07:58 PM   #6
crossy
Oh,you can't buy that new
crossy's Avatar
Post
everything is different especially the Senders. wiring is not a big deal to figure out though with proper manual but is actually a lot easier to just change inside harness, it is so easy to find 'Gauged' dashes in these year trucks that a bone yard can probably supply one for $25 or so. take some tape and pen to label things and unbolt the whole fuse box from the firewall. engine side first. grab the senders you need also some like the O.P. gauge are costly .DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
