01-05-2011, 09:57 PM | #1 |
whats different on 71,72 front suspension parts?
It seems to be harder to find parts for the 71-72 front ends ( drop spindles, upper & lower balls joints etc.) Can I use 67-70 parts?
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
01-06-2011, 11:04 AM | #2 |
Re: whats different on 71,72 front suspension parts?
ttt for you .
01-06-2011, 11:34 AM | #3 |
Upper ball joints, tie rod ends, and drag link are different.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-06-2011, 11:45 AM | #4 |
I've had no issue finding those parts for 71-72. From local auto parts to board vendors, they seem to all have those parts in stock and readily available. Only difference being brand and quality between sources.
01-06-2011, 03:56 PM | #5 | |
67-72 parts collector,…
Also,... what year truck are you working on?
01-06-2011, 06:20 PM | #6 |
Lowerball joints are different as well. If you are swapping from 67-70 to 71-72, you will need the following parts: Upper and lower ball joints for 71-72, inner and outer tie rods and sleeves for 71-72, drag link for 71-72, spindles for 71-72. Parts you can reuse: pitman arm, end link on pasenger side. Hope this helps, just did a swap on 68 from drum to disk and used the rotor/caliper line kit from GMC pauls- $350 +/-. you will need to buy a reman 71-72 disk brake master cylinder $25 and a prop valve either used or on ebay for roughly $50. You will need to buy a pair of adapter bushings to reduce the upper lines from 1/4 to 5/16 at bottom of prop valve, you will also need a 1/4 to 1/4 compression fitting and a 8" length of steel line that is 1/4 to the correct end (size escapes me at the moment) to fit in the rear of the prop valve. With replacing ball joints and bleeding/install figure a good sat. or roughly 5 hours. It is a 1 man job until the bleeding of the brakes. It is pretty straight forward and the kit from GMC pauls uses good components, wheel bearings, seals, calipers, hoses and pads. Easy to do, just dont rush. Hope this helps.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
