Old 01-05-2011, 10:42 PM   #1
BigPhil66
BigPhil66's Avatar
I Started The Front Suspension/Disc Brake Upgrade. A Few Pics
Well,, after working my Azz off at work and being sick for over a week...I finally started the Suspension/Disc Brake Upgrade. Working by myself weak as a little boy I beat the crap out of those ball joints which I am willing to bet are original...I got all but one. For those that don't know, this is on my 66 Chevy truck project which I converted the manual steering to power and now changing almost all the front suspension parts with a bit of a drop (front & rear) and Disc brake upgrade (front & rear). I still need to get the last ball joint off and remove the A arms to replace the bushings/media blast...as you can see the underside is covered in years of dirt. Here are a few pics...I like the last one of the new tie rod ends with the turn buckles...Purdy!!
more to come.
BigPhil66 is offline   Reply With Quote
Old 01-05-2011, 11:22 PM   #2
stealth_weapons
Re: I Started The Front Suspension/Disc Brake Upgrade. A Few Pics
where did you get the parts from/how much? if you dont mind me asking. i am waiting on my tax return to do the exact same things, disk brakes (all 4), front end rebuild kit, sway bar kit, drop spindles, etc...(all from CPP i think) should ride like a brand new truck
stealth_weapons is offline   Reply With Quote
Old 01-05-2011, 11:41 PM   #3
BigPhil66
BigPhil66's Avatar
That is where I got my parts. My dad and I may a day of driving into Orange County picked up the parts and had lunch. I believe it was 1,500 for the complete kit that they were offering after taxes. I just went on there site and I couldn't find the kit that I got but all the components are there. The only things that I didn't get for the front is the A arms and tie rod...everything else was included in the kit. For the rear I got the brakes, shocks, & springs.
Old 01-06-2011, 12:06 AM   #4
daverod
SSN 706
daverod's Avatar
A 10 lb sledge works great. Also know as a BFH.
daverod is offline   Reply With Quote
Old 01-06-2011, 12:12 AM   #5
Ratone71
Ratone71's Avatar
Love the sledge hammer! The only way to go!
Ratone71 is offline   Reply With Quote
Old 01-06-2011, 12:13 AM   #6
BigPhil66
BigPhil66's Avatar
Ah....I need 10lb sledge and maybe that ball joint fork. Will that work on the bottom ball joint? The tops popped like nothing and the passenger side bottom with about 6 good wacks. The driver side lower will not budge. I am going to see if I can borrow the neighbors torch if I have to.
Old 01-06-2011, 12:20 AM   #7
daverod
SSN 706
daverod's Avatar
I used it on the bottom. Thats the one that required the BFH. I beat on it for about 20 min with the LFH. Most auto places will let you use the fork.
Old 01-06-2011, 12:28 AM   #8
BigPhil66
BigPhil66's Avatar
Yea, here in Cali we have to rent the tool with 20 or 30 dollar deposit but I think I can get it even if I have to go by a BFH since I can always use one of those. Thanks!
Old 01-06-2011, 12:30 PM   #9
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I would concider getting your parts from ECE, instead of CPP. lots of neg feedback about CS for CPP on the board check out the review section.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-07-2011, 04:06 AM   #10
BigPhil66
BigPhil66's Avatar
What if I forget where the shims were...front, rear, driver side, passenger side? How hard woul it be to get the front end back to where it needs to be?Can an alignment shop fix it?
Old 01-07-2011, 10:34 AM   #11
daverod
SSN 706
daverod's Avatar
I'm pretty sure you'll have to take it to a shop anyway. That's what pictures are for.
Old 01-07-2011, 10:38 AM   #12
allengator
allengator's Avatar
I would think that where the shims USED to be will no longer be relevant...
Let them start from scratch...
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 01-07-2011, 01:31 PM   #13
BigPhil66
BigPhil66's Avatar
There was so much caked up crap that I really couldn't tell what is what. I know where they go its just that there are 3 different size shims and a spacer creating a gap for each bolt and I don't want to mix them up. I guess like measuring the tie rod ends to get the steering as close to where it was so that there is little adjustment...I want to try to do the same for the A arm. It will probably cost the same either way....I hope.
I probably that I could let them start from scratch but I will also need to drive the truck to the alignment shop. The truck drove good when I bought it, nice and straight and smooth so I am hoping that I don't crew that up. I am a rookie at this even though my dad was a master mechanic...he has forgotten a bit in his many years although he did warn me about the shims.
Old 01-07-2011, 03:04 PM   #14
daverod
SSN 706
daverod's Avatar
I would put the shims back in. I don't think you get full arm travel with out them. Maybe you do on a normal truck I know on my 66 I did'nt put the shims in and it would'nt lay frame. I guess if your just driving to the shop that would'nt matter.
Old 01-07-2011, 03:34 PM   #15
protrash64
Resistance is Futile
protrash64's Avatar
To get that lower to pop I had to jack up the drum so the spring would push down on the balljoint and air hammer in the pickelfork on its side to get enough wedge. I think I had something else in there too; cant remember!!
Lot's of fun!!!!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-08-2011, 02:33 AM   #16
BigPhil66
BigPhil66's Avatar
I have the shims zip tied to a cardboard and labeled and I am for sure going to put them back where they were.
Lot's of fun!!!!!!
I also used the jack on the drum and with three wacks it popped.
Old 01-08-2011, 09:51 AM   #17
protrash64
protrash64's Avatar
I also used the jack on the drum and with three wacks it popped. [/QUOTE]
.......always nice when that happens!!! Downhill from here!
About the shim packs: I just needed to do some driveway adjustments on my alignment after lowering. My truck had positive camber( top of tire leaning out) so I measured and reduced the shims by an equal amount front/rear to get a negative camber situation. I measured from the frame to the rotor to get an equal measurement on both sides.
Old 01-08-2011, 04:21 PM   #18
stealth_weapons
maybe i missed it but what wheels are you going with?
Old 01-09-2011, 02:53 AM   #19
BigPhil66
BigPhil66's Avatar
About the shim packs: I just needed to do some driveway adjustments on my alignment after lowering. My truck had positive camber( top of tire leaning out) so I measured and reduced the shims by an equal amount front/rear to get a negative camber situation. I measured from the frame to the rotor to get an equal measurement on both sides.[/QUOTE]
Thanks...good info that I can use.
I have some 17" Eagle Alloys that I don't even know if they are going to work. I got them from my brother in law. These are the wheels. Not exactly what I wanted but I got them in a trade...still not sure but I will probably go Old school.
