01-05-2011, 11:05 PM | #1 |
Horn problem
I have a grant wheel for my tilt column http://www.grantproducts.com/products/view/109/ and the problem that I am having is with the horn. I have it unplugged for now otherwise it will just honk until the battery is dead. The kit I was told to use is a 3163 and I have followed the instructions to the letter http://www.grantproducts.com/files/i...7508-00-01.pdf
Has anyone been seen this problem and been able to fix it? Thanks
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-06-2011, 01:58 PM | #2 | |
Re: Horn problem
who would think a simple thing like a horn could be such a p i n a. Last edited by glider_6969; 01-06-2011 at 02:00 PM. Reason: add more infor |
01-06-2011, 02:10 PM | #3 |
Re: Horn problem
My guess would be the horn press button, if it's not assembled right it would do that, are you able to push the button down?
'68 C10 LWB 6.2NA/NP833 3.73's |
01-06-2011, 02:13 PM | #4 |
20' Daredevil (Ret)
Re: Horn problem
I agree it sounds like a ground problem, but you may be able to look for it without using earplugs or annoying the neighbors.
When the horn button is pushed, it sends a ground to the horn relay (under the dash). The relay then sends -12V to the horns. It will click audibly when it closes and when it releases. Unplug the horns and listen for the relay to click while you chase the problem. If it helps, connect a test lamp to the wire that goes to the horns. If it is lit, the relay is closed and the horns would be blowing. If the light is off, the horns would also be off.
01-06-2011, 02:24 PM | #5 |
Re: Horn problem
grant wheels and beepers have been notoriously bad for the past 45years or so that i've had experience with them
agree that premature grounding is the cause
01-06-2011, 03:53 PM | #6 | |
Big Red - Now its a SWB!
Re: Horn problem
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
01-06-2011, 09:45 PM | #7 |
Re: Horn problem
Thanks for the info folks. I will give it a shot in a few days and reply back.
