C10/C20/C30 Frame
Is there any differences between the three? I'm looking for a dually but have access to a C10 frame and was wondering about strength/load capacities. Not that I'll be doing much work with this truck, I'd just like some peace of mind.
Re: C10/C20/C30 Frame
not really for the 1/2 ton and 3/4 ton but the 1 ton frame is FAT!!!
What do you mean by fat? Thicker?
yes lets just say a 1/2 ton 3/4 ton frame is 4 inches well the 1 ton is like 6 inches or maybe 7 huge frame!
hey there im new here, but hes right the one ton frames are normally an inch and half taller than the 1/2 and 3/4 and the steel itself is thicker as well. i have one of each and you can really see the difference in strength..
[B][COLOR="Navy"]BUTTERS 72 Chevy longbed C-10 72 Chevy 4x4 Longbed |
tryin to c ut a c notch in a 1 ton frame would take forever!!! if somone was gonna do that
its all about the +6 inches
the 3/4 ton is a tick thicker than the 1/2 ton and also has added braces bolted to it. The one ton is a taller C channel, and is thicker than the 3/4 ton. The one ton also only came with leaf springs.
why do our bumpers have extra holes on them for brackets that none of these trucks have??
Thanks for the info guys!
Vintage 4x4s
He was saying the one ton only came with leafs. Not the only one that came with leafs was the one ton.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
If you have any search mojo, I did a post a few years ago showing pictures of the differences between the 1/2 and 3/4 ton frames.
#13 |
Well my stock 69 K/20 frame (3/4 ton) was upgraded to 1 ton axles..and it hauls over 5,000 lbs on a daily basis and it is doing just fine...
1987 front dana60 dually 4.10 2003 chevy van cutaway 14 bolt FF rear. Just put in a 4speed /rockwell as it was when it was a 3/4 4x4 longbed. 8 foot flatbed dump. and its a 4x4 dually that gm should have built but never did total gvw is 11,290 its a little hard to see..5,320 lbs on this load I had an 80 3/4 frame and i kinked it behind the cab with 5,000lb on it..The older frames are better...and strong. Last edited by 70BLAZERX2; 01-06-2011 at 09:15 PM. |
#14 |
most gmc 1/2 ton shortbeds were leaf spring on the rear too.
#15 |
This is my 67 3/4 2 wd I also haul over 3500-5000 pounds most days. 2 1/4 wide spring and Air over leaf. I am always looking for a clean Longhorn frame here in ontario to put under it one day.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 01-06-2011 at 10:14 PM. |
