Old 01-06-2011, 04:49 AM   #1
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Just got factory Efans
Just scored some factory electric fans from the junkyard for $145. Great deal for up here.
I've already got them all installed and working. I built my own wiring harness off of a wiring diagram for the factory electric fans from 05+ trucks. It uses 3 relays which are switched off of the PCM via pin 42 and pin 33. I setup my tune with HP tuners and set the turn on and off temps of both the fans and the AC pressure on off temps so the fans kick on when the A/C is running. So far so good!
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-06-2011, 10:02 PM   #2
orange70350
orange70350's Avatar
Re: Just got factory Efans
hi i just came into a set of fans like the ones you have. i was woundering if you can give me a few more detailes on how to make a wiring harness for it and set them up i have a 2000 silverado thanks
orange70350 is offline   Reply With Quote
Old 01-06-2011, 11:07 PM   #3
loudnlifted88
loudnlifted88's Avatar
what kid of vehicle did those come out of im looking for a set like that to make fit in my truck thanks
IM ONLY 18 AND LOVIN IT
IF MUD AINT FLYIN YOU AINT TRYIN!
1badgmc- Just think. Someone worked hard to make it look that bad.
1988 chevy stepside 305 five speed Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383945
1994 GMC ext. cab short box 350 auto Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438873
1996 GMC 2500 ECSB 454 4l80e: build thread http://www.gmt400.com/forum/showthre...gmc-2500-build
1998 GMC K-1500 ECSB 305 auto partd truck
1999 GMC K2500 suburban 350 4x4 Dads project
1981 Corvette 350 auto Also Dads project
1989 Corvette 350 auto ^^
1998 GMC K1500 ecsb 305 auto Brothers project
loudnlifted88 is offline   Reply With Quote
Old 01-07-2011, 12:11 AM   #4
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
those came on the '05 and up trucks. I use a set of fans from an ls1 camaro.
'85 swb
droppedgmc is offline   Reply With Quote
Old 01-07-2011, 04:47 AM   #5
matthew20061
69' Chevy Stepside
Here's the wiring diagrams I used to build my harness. The last one is the one I used, the fans are controled via pin 33 and pin 42 on the pcm. Research it on performancetrucks.net there tons of info on this swap there. Couldn't have done it without reading everything on that site.
-Matthew
Old 01-07-2011, 09:12 AM   #6
loudnlifted88
i though they also cam on 02 and up tahoes
Old 01-07-2011, 12:08 PM   #7
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Great score! I really dig those fans used on the later GM trucks.
DirtyLarry is offline   Reply With Quote
Old 01-11-2011, 04:27 PM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I'll have to look into some of these for my 01 Hoe, not only for performance/mileage, but also because my A/C doesn't work all that well when sitting at a standstill.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-11-2011, 06:34 PM   #9
matthew20061
69' Chevy Stepside
It's a great upgrade for sure! I think I read that some of the trucks like your tahoe might have the narrower radiator 28" I think? So the Efans might not bolt on unless you swap to a different one, I think 32", which comes standard on the SS models and HD's I think. I think thats what I read at least might want to check into it though, as they sure look nice under the hood. Looks completely factory!
-Matthew
Old 01-12-2011, 01:02 AM   #10
Jacfourteen
Thanks for the info, I'll look into it.
Old 01-12-2011, 11:17 AM   #11
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
that is correct. they did use a bigger radiator for the factory efans
You'll need the 34" Radiator from 05+ trucks or 00-04 2500 series trucks
'85 swb
