Old 01-06-2011, 10:37 AM   #1
CrashBob
CrashBob's Avatar
Rear Brakes self adjusting
Hey,
I recently did a complete brake overhaul on my '67 C20 and after driving it maybe 200 miles, the rear brakes locked up after I backed out of a parking space. I had to take off the wheels and back the adjusters down so I could get home.
When I got it in the garage to see what broke, everything looked fine. It has started to ''auto adjust'' again. Any ideas? I took pix before dis-assembly and put em back the same way. Also why are the adjuster slots on the drums? What a pain!
In advance, thanks for any help offered
CrashBob
"Life is all about ass. You're either covering it,laughing it off, kicking it, kissing it, busting it or trying to get a piece of it.
CrashBob is offline   Reply With Quote
Old 01-06-2011, 11:14 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Rear Brakes self adjusting
The self adjusters should work only when the brakes are out of adjustment (at least that's the theory). So if they're adjusted properly, then definitely something else is wrong with them. I'll look up some pics for you.
Make absolutely sure that it's the brakes and not the rear rubber brake hose
swelled up internally. It's the one on the rear axle to the frame. It prevents the fluid from returning to the master cylinder. Common problem on these old trucks.
http://auto.howstuffworks.com/auto-p...rum-brake2.htm
68gmsee is offline   Reply With Quote
Old 01-06-2011, 11:21 AM   #3
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
This, when you hit the brakes, it will keep the pressure from bleeding off for quite a while, then when it does, it seems as if all is fine, till you use the brakes again.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 01-06-2011, 03:49 PM   #4
CrashBob
CrashBob's Avatar
Ah Hah!! That hose issue makes a lot of sense! I will change it out as soon as I get back from a job in CA.
Thanks!
I've said it before and I'll say it again...This forum and the people on it can't be beat, the greatest!
CrashBob
Old 01-06-2011, 06:37 PM   #5
cparman
sharp as a marble
I would think that if the rear brake hose was collapsed, and that was what was making the brakes stay on, you should be able to open the bleeders and relieve pressure? I have seen a brake drum that is too thin ( past minimum thickness ) flex so much that it allowed the self adjusters to keep on adjusting. To the point it burned the brake shoes clean off. Might check to see if the drums have plenty of meat left.
cparman is offline   Reply With Quote
Old 01-06-2011, 08:34 PM   #6
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Had the same thing happen to me on my C20 burb last weekend. Turned out to be a frozen-up parking brake cable. Every time I would go backwards, the adjuster would adjust the shoes so it would grab harder going forward. As a temporary fix, I just cut the cable near where it goes thru the brake backing plate.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 01-07-2011, 09:22 PM   #7
CrashBob
CrashBob's Avatar
All good ideas on possible causes!
Thanks again
CrashBob
