Old 03-10-2003, 11:53 AM   #1
67 CHEV MAN
Is head from the 250 the same as 292?
Need a little help, the head on my 292 is cracked. All I can find at boneyards are 250's. Will the head from a 250 go on a 292?
71 Cheyenne Swb 400/400 drivetrain.
My EBAY Auctions
67 CHEV MAN is offline   Reply With Quote
Old 03-10-2003, 12:07 PM   #2
dubie
dubie's Avatar
I think the block is longer on a 292
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-10-2003, 12:25 PM   #3
Canada20
just taller isn't it? I thought the 250 and 292 were pretty much the same, just a longer stroke for the 292 which meant they needed a taller block (actually, it's the same factory stroke as a 454...doesn't mean anything, just for interest's sake )
Greg
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 03-10-2003, 04:01 PM   #4
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
They are the same head. If you want to increase the comp ratio on a 292 (it is really low) use a 194 head. Same ports but smaller chambers.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 03-10-2003, 04:10 PM   #5
Canada20
Cool! I wasn't sure if that one would work or not; thought it might put the CR through the roof. I might have a use for my ol' 292 afterall!
Greg
Old 03-10-2003, 07:41 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Hey Canada, Go to www.inlinersinternational.com for everything you ever wanted to know about 6 cyl.power and then some.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-10-2003, 07:59 PM   #7
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
True, the 250 head is the same as a 292. It will bolt right on. They did come with a real low comp. ratio and like someone said you might try and find one off the even smaller 6 clynlinder to get your comp up there, or put in some different pistojns
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 03-10-2003, 08:54 PM   #8
72bigblock
get the head for a 194 6 cyl. 62-65 chevy II nova chris
72bigblock is offline   Reply With Quote
Old 03-10-2003, 09:21 PM   #9
big_ac2001
back in the mid 70s my dad raced stock cars. the class they ran was the 6 cylinder class. one time they build a 292. they decided to use a 194 head to get more compression. they shaved both the head and the block, and used flat top pistons. the engine had so much compression that the starter wouldn't turn it over. They hooked it up to the back of a truck and pulled it down the road to get it started. when they got it back in the shop, they pulled the head off and the head gasket was blown in 3 places.
'71 Custom 10 lwb, 327ci, TH350
'49 chevy 3100 5 window truck. 235 six cylinder. 3 speed on the column.
big_ac2001 is offline   Reply With Quote
Old 03-11-2003, 02:17 AM   #10
alta-aj
So what does the comp. ratio become?
With a 194 head on a 292, what is the compression ratio- assuming no shaving or other mods?
alta-aj is offline   Reply With Quote
Old 03-11-2003, 11:28 AM   #11
72bigblock
it should bump it up 1-1.5. chris
Old 03-12-2003, 07:17 AM   #12
'68OrangeSunshine
'68OrangeSunshine's Avatar
It's:
http://www.inliners.org
Old 03-12-2003, 12:01 PM   #13
Canada20
I used to hang around the Clifford site but I guess it's not around anymore?
Greg
