Old 01-06-2011, 02:35 PM   #1
daddybooz
daddybooz's Avatar
'68 Door Panel Hardware
Hi Fellas,
I had to take off the inner door panel to install new lockssets. The PO installed a carpet over the original metal door panel. In doing so, kind of half ACED it back together. There appears to be 4 on the bottom and two for arm rest a square threaded insert in the door that accepts a fastener. Well, I think there is only 1 left! I've found all other necessary hardware (thanks to Southern Kentucky ) to make right but I cant find these square threaded inserts anywhere!!???
Does anyone know where OR what other trick to make this work?
Thanks for your help, this forum is awesome!
Robert
DaddyBooz
'68 C10 LWB
KCP 406; 400 small block, 30 over, alum heads built by Kurt Clapper
Ceramic center dumps, custom 2 1/2" SS all the way back w/MagnaFlows
2"/4" drop on 15's
daddybooz is offline   Reply With Quote
Old 01-06-2011, 02:58 PM   #2
john
member #16
john's Avatar
Re: '68 Door Panel Hardware
Wes at Classic heartbeat has them.
http://www.classicheartbeat.com/
john is offline   Reply With Quote
Old 01-07-2011, 02:11 PM   #3
daddybooz
daddybooz's Avatar
Thanks John!
DaddyBooz
'68 C10 LWB
2"/4" drop on 15's
