Old 01-06-2011, 04:13 PM   #1
ldgn63
REAR SPRING retaining BOLT specs?
anybody know the specs for the REAR COIL SPRING retaining BOLTS? ('67 C10trailing arm)
upper and lower...
I assume grade 8
all help appreciated (mine are broken and or rusted beyond id)
Thanks!
ldgn63 is offline   Reply With Quote
Old 01-06-2011, 05:29 PM   #2
BIGBLU 72
BIGBLU 72's Avatar
Re: REAR SPRING retaining BOLT specs?
yeah GRADE 8! im getting some tomorrow bc im going to have to torch them out! the heads are 3/4 in no clue about the tread! make sure you get the washers, nuts, and lock washers in grade 8 as well! ps i think the upper ones are like 2 inches long and the lowers are like 5 inches???
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 01-06-2011, 05:34 PM   #3
rvn1038
Don't know what size, but for around $20 you can get all the bolts, nuts, washers and cups from CPP.
rvn1038 is offline   Reply With Quote
