Old 01-06-2011, 08:17 PM   #1
blazer2007
a.c & stock heater firewall the same?
Will a ac heater unit fit in the firewall that had a stock non ac unit and vice versa on a 78 truck.It looks like the ac unit is larger on the firewall.I,m talking about the fan and box unit that bolts on the firewall in the engine compartment
blazer2007 is offline   Reply With Quote
Old 01-06-2011, 08:35 PM   #2
blazer2007
Re: a.c & stock heater firewall the same?
I found a pic and the ac unit looks quite large,is there a plate to change from the ac unit to a non ac unit ?
Old 01-06-2011, 09:10 PM   #3
80SPORT
80SPORT's Avatar
The hole for the a/c trucks is different than the standard units but it is not hard to modify either way as the firewall is flat in that area.
80SPORT is offline   Reply With Quote
Old 01-06-2011, 10:54 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
the hole is in a different spot and is in a different shape, i put ac off a 79 on a 78, and the 78 did not have a/c previously.
i made a template off the a/c cab. layed it on the other cab, cut the whole bigger and filled in the rest, drilled some holes and mounted up the box
79 firewall
79 firewall with template
78 firewall after modification:
all painted
the box
95 S_Trucker is offline   Reply With Quote
Old 01-07-2011, 11:38 AM   #5
blazer2007
Ok thanks,it just that a friend has a truck up north but he doesn,t want the ac [no use up there]and he will trade me for mine[and i need air down here in the summer]We were just wondering how they would inter change but it looks I have to do some cutting and he has to make a plate
Old 01-07-2011, 03:26 PM   #6
Keith Seymore
Keith Seymore's Avatar
79 firewall
all painted
the box
Nicely done, and good input, too.
I like the note on your template...
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-07-2011, 07:20 PM   #7
95 S_Trucker
when there are other people in your shop things tend to disappear sometimes, and there was a 3 week period between making the template and cutting the cab
