01-06-2011, 09:11 PM | #1 |
Alternator bracket question.
Does anyone have a picture of this set up installed?
I'm trying to relocate the alternator to the passenger side. I'm told this set up works but I can't figure it out. Any help would be great. |
01-06-2011, 09:15 PM | #2 | |
Re: Alternator bracket question.
01-06-2011, 09:15 PM | #3 |
Do you have headers?
01-06-2011, 09:20 PM | #4 |
01-06-2011, 09:26 PM | #5 |
HOW long until spring??
These are old pictures for the brackets i have on my Chevelle 327. The heads are pre 69 which have no attachment holes. The bracket bolts to the exhaust manifold In the bottom pictures you can see a black brace I made to help support things as it was a little loose when the belts came tight. It goes all the way down to a pair or threaded holes down low on the block The first L shaped piece bolts to the manifold, the second piece bolts to the first which allows it to slide back and forth for belt alignment
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 01-06-2011 at 09:33 PM. Reason: added text |
01-06-2011, 09:30 PM | #6 |
I believe you have to stack them. The middle bracket attaches to the header and then the bracket on the right is attached to it.
01-06-2011, 09:33 PM | #7 | |
01-06-2011, 09:35 PM | #8 |
Just wait until you get old....really sucks then
01-06-2011, 09:36 PM | #9 |
My alternator was on the drivers side at first, I moved to the passenger side when I put on the power steering. Let me know if you need more pictures
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
