Old 01-06-2011, 09:19 PM   #1
wxman1
Engine ID
Have a 69 Chevy C10 P/U. I was told by the previous owner that the engine
was actually from a Monte Carlo. So I went looking for the engine ID. Am attaching
an image of the engine boss with the ID info. Went to nastyZ28's website and found
the following info. d
2 numbers: Engine code stamping number = V0613CMF
VIN# = 17D496727
These numbers are clearly visible if you zoom in on the engine boss.
So the stamping number decodes to Flint, MI, June 13th, suffix CMF = 1975 Monte
Carlo, 350 ci. The VIN = 1(Chevrolet) 7(1977) D(Doraville).
Whoa!!! Wait a minute!! 1977???? That doesn't match the stamping code.
Anybody know what is going on here??
Jim
wxman1 is offline   Reply With Quote
Old 01-06-2011, 09:25 PM   #2
70BLAZERX2
Re: Engine ID
It may be hard to do , but get the casting date off the top rear of block under the distributor..This will conform year..should be dated ?/?/74
nasty z says its also a 4speed motor with calif..emmis..
70BLAZERX2 is offline   Reply With Quote
Old 01-06-2011, 09:29 PM   #3
70BLAZERX2
Re: Engine ID
this is showing it a 77 chevelle 350
go to parts id, suffix codes are on the bottom left.
http://www.chevymania.com
