Old 01-06-2011, 09:26 PM   #1
k1rodeoboater
turn signal is being problematic....
I just rewired my turnsignal harness as a temp job till I do it for real. The previous owner did quite a ghetto job of rewiring it and I sought to correct it so I actually had working signals. My problem lies inside the steering column I believe. The right signal works perfectly fine, locks in annd flashes. The left doesn't flash when it locks, however if I add a slight bit of downward pressure to the arm it flashes.
Is there an adjustment I can do to fix this or do I need to replace the harness/components in the column?
k1rodeoboater is offline   Reply With Quote
Old 01-06-2011, 10:33 PM   #2
dracko
dracko's Avatar
Re: turn signal is being problematic....
My 64 was doing the same thing when i bought the truck. A small plastic tab inside had broken off the cam plate inside the column. I ended up buying a new Turn Signal switch w/Harness and it works like new now. You may be able to get away with just replacing the cam plate, which is $8...I bought the whole assembly and paid about $50.
dracko is offline   Reply With Quote
Old 01-07-2011, 09:56 AM   #3
k1rodeoboater
You have to pull the wheel to get to it correct?
Old 01-07-2011, 10:21 AM   #4
ChevySixty6
ChevySixty6's Avatar
Yes you will need to pull the steering wheel off. There has been several
threads on the safe way to do this, so you don't end up missing a couple
of teeth.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 01-07-2011, 10:46 AM   #5
k1rodeoboater
I will look up those threads later. I will probably just replace the whole turn signal assembly if I have to pull the wheel....at that point why not
