01-06-2011, 09:33 PM | #1 |
offset vs backspacing...I KNOW A DEAD HORSE
ok Im talking to the tire guy and he says..
20x8.5 with a 14 offset is just a hair over 5.25 and 22x10 with a 1 offset is just a hair over 5.5 Make sense OR did I completely not understand what the heck he said?!?!? Im trying to get a 5.25 in front and a 5.5 BS in back. Thanks! I think Foose Legends are going on my baby soon.... |
01-06-2011, 09:46 PM | #2 |
Tot Roddin'
Re: offset vs backspacing...I KNOW A DEAD HORSE
What year rearend do you have?
I'm running a the following on a stock '69 rear end and a disc brake/drop spindle upgrade: Billet Specialties Vintec's Front: 20x8.5" w/ 5.5" BS - Center Bore: 3.430 - Bolt Pattern: 6 on 5.5" Rear: 20x10" w/ 4.75" BS - Center Bore: 4.250 (due to the center hub on the rear axle of my '69 [meas. 3.5"; BS only offered 3.43]) - Bolt Pattern: 6 on 5.5" Toyo Proxes S/T ii's Front: 255/40-20 Rear: 295/40-20 If I had chose to run bags, I would have increased the front BS to 5.75", and changed my rear to probably a 5.5" to account for getting the wheel higher in the wheelwell when aired out. 4.75" in the rear will work on bags but will require the rear inner fender mod found here.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-06-2011, 09:51 PM | #3 |
Tot Roddin'
According to http://www.convertunits.com/from/mm/to/in
14mm = 0.5511811023628 in I think you failed to post the rear BS measurement. mm inches inches mm inches inches 1 - 0.04 0.63/16 26 - 1.02 1 0.38/16 2 - 0.08 1.26/16 27 - 1.06 1 1.01/16 3 - 0.12 1.89/16 28 - 1.10 1 1.64/16 4 - 0.16 2.52/16 29 - 1.14 1 2.27/16 5 - 0.20 3.15/16 30 - 1.18 1 2.90/16 6 - 0.24 3.78/16 31 - 1.22 1 3.53/16 7 - 0.28 4.41/16 32 - 1.26 1 4.16/16 8 - 0.31 5.04/16 33 - 1.30 1 4.79/16 9 - 0.35 5.67/16 34 - 1.34 1 5.42/16 10 - 0.39 6.30/16 35 - 1.38 1 6.05/16 11 - 0.43 6.93/16 36 - 1.42 1 6.68/16 12 - 0.47 7.56/16 37 - 1.46 1 7.31/16 13 - 0.51 8.19/16 38 - 1.50 1 7.94/16 14 - 0.55 8.82/16 39 - 1.54 1 8.57/16 15 - 0.59 9.45/16 40 - 1.57 1 9.20/16 16 - 0.63 10.08/16 41 - 1.61 1 9.83/16 17 - 0.67 10.71/16 42 - 1.65 1 10.46/16 18 - 0.71 11.34/16 43 - 1.69 1 11.09/16 19 - 0.75 11.97/16 44 - 1.73 1 11.72/16 20 - 0.79 12.60/16 45 - 1.77 1 12.35/16 21 - 0.83 13.23/16 46 - 1.81 1 12.98/16 22 - 0.87 13.86/16 47 - 1.85 1 13.61/16 23 - 0.91 14.49/16 48 - 1.89 1 14.24/16 24 - 0.94 15.12/16 49 - 1.93 1 14.87/16 25 - 0.98 15.75/16 50 - 1.97 1 15.50/16
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 01-06-2011 at 09:55 PM. |
01-06-2011, 09:56 PM | #4 |
67-72 parts collector,…
Here's a good offset chart that I use,...
01-06-2011, 09:57 PM | #5 |
Tot Roddin'
Right-click and save.
01-06-2011, 11:45 PM | #6 |
So what he said makes sense...
I have a PB DM and trailing arm kit with what I think is a 67 rear end! Thanks for the info guys....just wanted to run it by a 3rd party (alotta 3rd parties) before ordering! Posted via Mobile Device |
01-15-2011, 05:21 AM | #7 |
ok now im confused... :P
BS is how much room there is from the back flange to where the mounting surface is inside of the rim... check. (i.e 5 or 5.5 back space) Offset is how the rim centerline is in regards to the whole rim right? has nothing to do with backspacing, just how dished the rim looks from outside? Maybe I just got it all wrong..lol Now for my stupid question... (i.e. 5 or 5.5 in backspace) thats in inches? I think Im just gonna find someone on the site that has 6x5.5 wheels... has drum brakes.. has a stance that I like.. then get the same exact thing he did.. that might be easier...
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 |
01-15-2011, 10:04 AM | #8 | ||
Yes, backspace is measured in inches, but for whatever goofy reason, these charts are refering to the off-set in millimeters? Why? I have no idea.....seems stupid to me. Most people in the U.S. do not use metric measurments with enough frequency to deal with it. So you use one chart to get a number, then another chart to convert that mm to inch. Think of the difference like this. BS does not change with with wheel width, it is a constant. An 8" wheel with 4.5" BS will look exactly the same as a 10" when viewed from the back, the "addition" is all out the front. Now, if you have a an 8" wheel with zero off-set and another that is 10" wide with the same zero off-set, you will see the difference on both sides. It will be 1" wider on each side.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
01-15-2011, 11:31 AM | #9 |
Old School
Next time somebody throws some of them millimeters at you, just whup out the old cellphone, punch up the calculator, and divide by 25.4. You'll get your answer in good old complicated American inches. Also, some calculators nowadays have a unit conversion built in.
#1 Project...69 Chevy swb Fleetside (Dad's truck) #2...1983 El Camino SS (Choo Choo Custom) #3...1974 Datsun truck (4.3L V6/4L60E) #4...1951 Cadillac Limo (1975 Caddy running gear) #5...1938 Dodge M38 3/4 ton Military truck #6...1968 Sportster XLCH trail bike 5 GMC & Chevy parts trucks 68 to 72 Last but not least; My 1978 Harley Davidson Electraglide (trusted & reliable companion for the last 30 years) |
01-15-2011, 12:35 PM | #10 | |
The red numbers at the top,... are the "backspace" numbers in inches. Like you posted,... backspace numbers are real numbers. Offset numbers mean nothing,... unless you know the rim width. example: a 14mm offset on a 8" wide wheel is totally different than a 14mm offset on a 10" wide wheel.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-15-2011 at 12:37 PM. |
01-15-2011, 12:38 PM | #11 |
DrtyJack75,... your truck is BADA$$!
01-16-2011, 01:10 AM | #12 | |
Does that mean I should just find wheels that have No offset as opposed to ZERO offset? Im going to keep reading your post and that Diagram until I get it. later: GOT IT!!! Now what you were saying makes sense.. You just thought you were telling someone with a brain..lol Here are some crib notes for figuring out backspace, centerline, and offset. * Step 1: Measure the room in your wheel wells relative to the wheel hub. * Step 2: Backspace = The distance from back of the wheel to the wheel's mounting space, in inches. * Step 3: Centerline = The wheel width divided by 2, in inches. * Step 4: Offset = Backspace - Centerline, which will be positive or negative, in inches. * Step 5: Offset in Millimeters = Offset x 25.4.] from: http://www.truckinweb.com/tech/suspe...equations.html
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 Last edited by BadaSs_Cal; 01-16-2011 at 01:29 AM. Reason: No need to double post |
01-16-2011, 01:29 AM | #13 |
01-16-2011, 03:16 AM | #14 | |
Offset is Offset, and Back space is Back space.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
