Old 01-06-2011, 09:38 PM   #1
cb1965
cb1965's Avatar
headlights
i picked up a gmc grille and need headlights, all 4. how much do they cost and where can i get them.
thanks
cb1965 is offline   Reply With Quote
Old 01-06-2011, 10:05 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: headlights
You can spend a lot more for fancy units, but standard sealed beams are as near as you favorite parts store for about 5 bucks each. Here are the Napa versions:
Low beam:
http://www.napaonline.com/Search/Det...+50030+2030093
High beam:
Old 01-07-2011, 12:05 AM   #3
Heater63
Heater63's Avatar
Re: headlights
has anybody tried the LED units?? $$$$
www.truck-lite.com
292 + TKO500
Heater63 is offline   Reply With Quote
Old 01-07-2011, 12:49 AM   #4
blackmopar
Re: headlights
not to hijack, but not sure if you just need lamps or everyting.
i need the new back plates, trim rings, springs and hardware - I know LMC has that stuff (anybody else?) - wouldnt buy their headlamps though - pretty pricey
I found these - still pricey - but im looking for somethign with signal inside
http://dandsrodandcustom.com/index.p...product_id=269
blackmopar is offline   Reply With Quote
Old 01-07-2011, 01:01 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Re: headlights
Chevy Duty has most if not all of the parts. That's where I bought mine:
http://www.classicparts.com/Headlamps/products/200/
Old 01-07-2011, 01:49 AM   #6
blackmopar
Re: headlights
awesome Mark - thanks!
Old 01-07-2011, 02:51 AM   #7
62 Longbed
62 Longbed's Avatar
Re: headlights
blackmopar , If your looking for the everything behind the headlights , I might have the stuff .. Let me know if thats what your looking for .. I will dig thru my boxes of misc .. 62 Longbed
62 Longbed is offline   Reply With Quote
Old 01-07-2011, 06:02 PM   #8
cb1965
cb1965's Avatar
Re: headlights
Thanks Mark.
now.. halogen lights are better than stock right? so if i get halogen lights do i need to add relays even if i have all new wiring?
Old 01-07-2011, 06:29 PM   #9
blackmopar
Re: headlights
i added relays even to stock headlights - the benefit (MUCH brighter lights) is well worth it - IMO
Old 01-07-2011, 06:57 PM   #10
cb1965
cb1965's Avatar
Re: headlights
do you hava a part # for the relays? and where can i get them
Old 01-07-2011, 09:20 PM   #11
blackmopar
Re: headlights
you can get a harness kit from LMC but its chin-junk! I use Tyco (still foreign but a good quality piece) relays and did the wiring myself - theyre amazingly simple and Im NOT a wiring guy - I get my stuff from Mad Electrical - the dudes name is Mark - he knows his sh*t
http://www.madelectrical.com/
let me know if i can help with any other info - youll be stoked
Old 01-11-2011, 10:23 PM   #12
cb1965
cb1965's Avatar
Re: headlights
is the gmc grille a direct swap with a chevy grille? do i need to drill holes? if so , witch ones? maybe a diagram or mesurements
Old 01-11-2011, 10:51 PM   #13
blackmopar
Re: headlights
my 60-61 wasnt a direct fit to my 64 - the upper bolt hole is the same, but I had to drill the lower for the grill bracket - was shorter than the stock lower hole. You should at least be able to get it hung using the upper bolts then it should be obvious
