Old 01-06-2011, 11:53 PM   #1
c1069
c1069's Avatar
Backspacing in 71-72
Hi I want to make a change in my truck. I did the swap of 6 lug to 5 and I need to know the backspacing on some new wheels. I want to put 8" in front and 10" on back. Please any input would be appreciated. Thanks.
c1069 is offline   Reply With Quote
Old 01-08-2011, 02:23 AM   #2
stefan
New Member
Re: Backspacing in 71-72
Did you do the just the axle conversion or didyou put a 71 or 72 rearend.Iknow someone here can help.
stefan is offline   Reply With Quote
Old 01-08-2011, 02:27 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Stock height?
Static dropped?
Air ride?
What's your suspension plans?
Keith
Convert to disc brakes.
Old 01-08-2011, 01:51 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
What size wheels?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-08-2011, 01:55 PM   #5
Spoof
Spoof's Avatar
Does it have air conditioning?
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 01-08-2011, 01:57 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Confused... Won't really affect the backspacing on a wheel.
-Nate
Old 01-08-2011, 02:32 PM   #7
Spoof
Spoof's Avatar
Sorry...after all the questions as to the particulars I couldn't help but mimic the obviously non-pertinent questions you get when you try to order a part at an auto supply store.
Me: I would like an oil filter
Parts person: what colour is your truck?
71 GMC 1500 LWB
Old 01-08-2011, 03:06 PM   #8
lolife99
lolife99's Avatar
Spoof,... I understand your sarcasism.
But sometimes it's like "pulling teeth" to get all info out of the OP.
I only ask questions when I don't have enough info to give a good answer.
The wheel diameter is very important when it comes to backspacing numbers.
So is the amount of drop.
Keith
Old 01-08-2011, 06:08 PM   #9
Spoof
Spoof's Avatar
I'm sorry guys, I came across as making fun of you. I was trying to be funny but I wasn't inferring that any of the questions asked by members were irrelevant, in fact they were very pertinent and necessary to answer the bs question.
No dig or passive aggressiveness was intended, only a poke at parts store clerks!
Sorry to derail the post.
If it helps...my 18"X9.5" rear are 4.5" bs and the 18"X8" fronts are 4" bs.
4" drop springs back, 2.5 spindles front.
71 GMC 1500 LWB
Old 01-09-2011, 12:18 AM   #10
stefan
New Member
Hey Lolife you have always given me good advice,so lets do mine im about to buy wheels in i hope a month,my truck is a 5.5 front and 8 inch in the rear and i want 17 or 18 inch wheels 8.5 in front and 10 inch in the rear and the truck is a 72 swb,thanks bud
Old 01-09-2011, 12:20 AM   #11
c1069
c1069's Avatar
71 rear end
Stock height?
Static dropped?
Air ride?
dropped
Old 01-09-2011, 12:22 AM   #12
c1069
c1069's Avatar
Originally Posted by 72BlckButy View Post
What size wheels?
15" rallys
Old 01-09-2011, 12:22 AM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Originally Posted by c1069 View Post
71 rear end
dropped
Dropped how? Static, bags, etc.
In order to provide assistance to your question, we need to have more background into what you're dealing with. Also... what size wheel do you want to run?
There's a lot that goes into determining the correct BS to run on a set of wheels for them to fit "right."
-Nate
Old 01-09-2011, 12:25 AM   #14
72BlckButy
Tot Roddin'
72BlckButy's Avatar
If by dropped you mean staticly... how low are you? 2/4, 3/5, 4/6?
With running a set of rallys, all you should need on a 4" drop in the front will be a creative grinding on the lower a-arm since you are running disc brakes.
-Nate
Old 01-09-2011, 12:42 AM   #15
c1069
c1069's Avatar
4/6 ....front disc
Old 01-09-2011, 12:44 AM   #16
lolife99
lolife99's Avatar
If you ever plan on bagging it,... you have to tuck the wheels enough,... so they will clear when air'd out.
But for a static drop:
8.5" wheel in the front:
I would use a 5.25"-5.5" backspace.
10" wheel in the rear,... (with the wider 71-72 rearend housing).
I would use a 5.5" backspace.
Keith
Old 01-09-2011, 12:44 AM   #17
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Grind the a-arm.
Refer to:
http://67-72chevytrucks.com/vboard/s...4&postcount=61
Please provide enough information when asking for assistance; it really helps to determine everything that is involved.
-Nate
Old 01-09-2011, 12:52 AM   #18
c1069
c1069's Avatar
Grind the a-arm.
Refer to:
Thanks. I'll keep that in mind next time.
Old 01-09-2011, 12:53 AM   #19
lolife99
lolife99's Avatar
4/6 ....front disc
OK,...
4/6 drop
15x8 and 15x10 ralleys.
It would be nice to run greater than a 5" BS up front,... but that's not possible. 4" BS is the most with a 15" rim,... and that will require a little grinding on the lower a-arm in the balljoint area.
An 8" rim up front with a 4" BS may be close to rubbing the fender lip with a 4" front drop. It all depends on tire height.
I usually run a 7" rim up front when I use 15" wheels with that much drop.
The rear 10" ralleys will work with a 5"-5.5" BS.
Here's my '69 with a 5.5/7 drop on 15" truck ralleys.
(15x7's and 15x8's)
Keith
Old 01-09-2011, 12:55 AM   #20
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
this is frickin hilarious....
-Ron-
OldSkool71 is offline   Reply With Quote
Old 01-09-2011, 12:56 AM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Everything that lolife99 posted above is covered in the following two threads:
Project NO-Life: http://67-72chevytrucks.com/vboard/s...hlight=no-life
Project Blank Slate: http://67-72chevytrucks.com/vboard/s...d.php?t=353633
-Nate
