Old 01-07-2011, 01:42 AM   #1
coggonobrien
blazer fuel tank and efi bbc question
has any body used a blazer tank to feed a multi-port efi bbc? i'm looking to get a fast efi for my 427 and curious if i would be better of getting a fab purpose tank or could use my blazer tank with an inline pump. the tank was about a year old when i got the blazer.
Thanks!
david
coggonobrien is offline   Reply With Quote
Old 01-07-2011, 11:20 AM   #2
AJs72K5
AJs72K5's Avatar
Re: blazer fuel tank and efi bbc question
I thought about converting mine. The issue I saw was that the original tank isn't baffled. I also want to go with an in-tank pump. When I have fundage, I'll be ordering a fuel cell from either Dave Boyd or fuelcellguy.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 01-07-2011, 11:35 AM   #3
Burt4x4
Burt4x4's Avatar
454 Edelbrock MPFI Pro-Flo
NWMP 37gal tank w/internal baffeling
I use the external fuel pump that came with the Edelbrock Pro-Flo kit and I have had Zero issues...I even ran out of fuel once and didn't get any starvation issues until no more fuel was flowing.
My buddy ran a stock blazer tank with his LS engine and I recall him saying he can't let the fuel level get below 1/4tank or his fuel flow will skip a beat...esp when flooring it!
Good Luck Happy Friday!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-07-2011, 02:31 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
I've been told that people take units like this and put them in older non-baffled carb style tanks. The cup at the bottom does the work of the baffles and keeps fuel to the pump. In this case I guess you would have to cut another large hole in the top of the tank to bolt this in. Its a thought, I've been trying to find something like this that has the lock ring style top so It could just be dropped into my original tank. So far no luck.
Here is a pic
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-07-2011, 06:44 PM   #5
coggonobrien
sweet, how do you like the edelbroch setup burt? thats one option i've considered. as for getting under the 1/4 tank mark, i'm not going to say its not an issue but i live far enough from a gas pump that i will probably make sure its not an issue with the big block
Old 01-07-2011, 07:49 PM   #6
JMac11
JMac11's Avatar
I am going the way Critter posted. Repop Tank and Pickup like that for my LT1 swap
JMac11 is offline   Reply With Quote
Old 01-09-2011, 03:46 PM   #7
MikeS
Active Member
MikeS's Avatar
This is exactly the part I used when I did my TPI upgrade. Works great. The only problem is that the vertical part is too short and I needed to extend it about 2" to get to the bottom of the tank.
Here is a pic
The rides:
'72 Blazer 350/4spd/Tuned Port Injection
'69 Firebird 400/4 speed
2001 Dodge Dakota Sport 4X4/4.7L V8/5 spd/Headers/Jet Chip, etc. Daily Driver
2002 Airborne Zeppelin (roadbike) Titanium frame/Campy Chorus
2004 Filippi Italia S (rowing shell)
MikeS is offline   Reply With Quote
Old 01-09-2011, 04:17 PM   #8
Critter
Future TOTM Winner
Critter's Avatar
Did you use a stock blazer tank? How did you mount it to the tank? Have any pictures???
Old 01-10-2011, 11:10 AM   #9
Burt4x4
Burt4x4's Avatar
IT's kickass man! I had a hard time "tuning" it as I'm not a EFI guy....I can rebuild a carb but setting up EFI computer is ahh...confuzing hehehe
So I drove it too the nearest Dyno shop and had them tune it on the Dyno! Damn good thing I did it right away too as my Air/fuel was way off and would have burnt up my 454 in short time
Trottle responce is amazing
I have heard good things about the Holly Comander 950 EFI too. ( I think that is what they call it?)
Good Luck! BBCs errr FUN mmmmK!!
