Old 01-07-2011, 08:17 AM   #1
thunder71
thunder71's Avatar
Talking Performance Online POL ::anyone used this kit?
i'm now in the market to convert to disc brakes with a 2 1/2" drop spindle & this looks like me but was wondering if anyone has used this kit
http://www.performanceonline.com/196...d-6-LUG-16671/
_____________________________________
66 C10 shortbed stepside KEEPER
66 C10 longbed stepside SOLD
69 C10 shortbed stepside SOLD
71 C10 custom deluxe long fleetside SOLD
thunder71 is offline   Reply With Quote
Old 01-07-2011, 09:56 AM   #2
halfcockedcustoms
halfcockedcustoms's Avatar
Re: Performance Online POL ::anyone used this kit?
I am in the process of installing that kit on my truck now,,should get it done this weekend..I am really happy with it so far...
halfcockedcustoms is offline   Reply With Quote
Old 01-07-2011, 01:11 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
I just installed the 'conversion' kit on my '66. It uses original balljoints and tie rods as I felt mine were in decent condition. It's basically the same kit, however.
It fit, went together well, and was shipped quickly. It came with all parts needed. No complaints what so ever.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-07-2011, 02:00 PM   #4
blackmopar
man thats a nice looking kit - thats where i want to be too - im trying to figure out if its even worth trying to find a Donor 73-87 truck and do the swap but i figure any donor i get ill need to go through that front end with a compelte bushing replacement anyway - along with getting aftermarket spindles it seems $$ wise itd be a wash
although that still leaves M/C, Booster, and Lines to procure..........
Im guessing either way the whole conversion is gonna be around $1000, yea?
blackmopar is offline   Reply With Quote
Old 01-07-2011, 03:26 PM   #5
protrash64
protrash64's Avatar
blackmopar: Depends on the kit you get; 5-lug verses 6, powerbooster or not. I went with manual brakes and I believe the conversion kit is cheaper as it does not replace the tie rods/balljoints. If you need these items, the kit may be a bargain.
Also have to figure in brake lines/fittings/fluid and cleaning if you're so inclined to do so.(Cleaning, that is!)
Old 01-07-2011, 05:10 PM   #6
blackmopar
good points - i have some deciding to do - dont wanna hijack Thunder here any longer though - sounds like the POL kits are worthy though, eh?
Old 01-07-2011, 05:22 PM   #7
thunder71
thunder71's Avatar
hey hijack all you want
just wanted some feedback on this & sounds good so far...anyone else have this?
Old 01-07-2011, 05:33 PM   #8
63 & 64 Bowties
and a few others
Hey Thunder, I don't have anything to add about the kit except; have you checked on shipping yet?
I see you live just south of me, and I know from experience that shipping charges from west to east are a lot more than east to west. I have no idea why. And that's a pretty heavy box.
I bought from Brothers (in CA) once without even thinking about the shipping. My mistake, but when I questioned them about it they told me about the W>E shipping issue. At first I didn't believe it, but I confirmed with UPS that it's true.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-07-2011, 07:47 PM   #9
thunder71
thunder71's Avatar
yep shipping is $119.95......just placed order so i will see how it does, got the kit in the link to rebuild the front while i got it apart with the 6 lugs so i can use my wheels which are 15 x 7 slots...this picture is with the 3" drop springs from CPP which is just not enuff for me...
this is how it looks with the 3/5 drop springs installed...
this picutre is before the drop springs with tall tires...
Old 01-07-2011, 09:10 PM   #10
blackmopar
sweet dude - my truck sits pretty much the way yours does with the cpp drop so im def intersted to see the after shots with the POL kit - good luck and post pics soon!
Old 01-07-2011, 09:34 PM   #11
gimmy 64
ECE kit has everyting you need front brake lines ,master cylender and even brake line to the rear of the truck for not much more
gimmy 64 is offline   Reply With Quote
Old 01-07-2011, 11:07 PM   #12
protrash64
protrash64's Avatar
thunder71's fender to tire gap will be gone with the spindles (I'm assuming the 2.5'' drop). I dont know if you'll be able to use the 3'' coils.
Here is mine with a 1'' shorter coil minus 1 coil cut. 235/70/15's
Old 01-08-2011, 09:23 AM   #13
thunder71
thunder71's Avatar
Thumbs up Re: Performance Online POL ::anyone used this kit?
why do you say i might not be able to use the 3" drop coils? i am running 235-70-15" tires...yes the kit is 2 1/2" drop spindles...i'm looking for a little rake in the stance...
Old 01-08-2011, 09:43 AM   #14
protrash64
protrash64's Avatar
I guess I didnt type out a complete thought........yes, you can use the coils; I have the same set-up on my shortbed 2.5'' spindle+3'' coil for drop. The problem potentially could be the tire/wheel fitment in the front. Unless you get the high $$ modular spindles the standard drop spindles push the stance out wider in front. My combo pictured above has the tire right above the fender lip with the Rally's having 4.25'' backspace. You will be an inch lower; there is no doubt it will look kicka$$() but you may not be able to turn or if you turn and drive into a rising slope you may peel your fender lip out.
Again, it depends on the backspace and wheel tire combo.
Old 01-08-2011, 12:02 PM   #15
thunder71
thunder71's Avatar
i just went out & checked the distance now & with a straight edge on the outside of the tire to the most inner side of the fender where the roll is is 1"... so your saying the dropped spindle will move the tire outwards? i hope not much...
Old 01-08-2011, 02:35 PM   #16
halfcockedcustoms
I finally got the rotors on last night,,,,This is how it sits with the POL kit and 2 inch coils with one coil cut and no engine,,sorry for the cellphone pics
Old 01-08-2011, 03:35 PM   #17
Rich 5150 69
Rich 5150 69's Avatar
ECE will tell you that the dropped spindles/disc brake will move your hub center line out 3/4 inch per side....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-08-2011, 08:08 PM   #18
thunder71
thunder71's Avatar
wow 3/4" that's alot
halfcocked,did yours move out that much? is your wheel going to clear the fender with a motor installed? looks good like it is..
Old 01-08-2011, 09:48 PM   #19
halfcockedcustoms
to tell the truth,,,I dont really know if it did or not,,and it seems like the tires will clear,,,here is a before pic to compare the 2
Old 01-08-2011, 10:45 PM   #20
lolife99
67-72 parts collector,…
lolife99's Avatar
A 2" drop coil with 1 full coil cut will equal a 4" drop coil.
I would install your 3" drop coils and see where it sets.
You can always run a shorter tire.
Keith
Convert to disc brakes.
Old 01-08-2011, 10:47 PM   #21
lolife99
lolife99's Avatar
thunder71,... by the way,... you have a cool truck!
Keith
Old 01-08-2011, 11:23 PM   #22
RollinKaos
RollinKaos's Avatar
I want to see how you come out after the install. I too have the 3/5 CPP drop and want to go with 2 1/2 " drop spindles. I am running 235/75 15 on my ride right now but will most likely be running 15x 8 rallys with 235/60 15 up front and 275/60 15 out back. The stance on my truck does not seem as low in the rear as yours Thunder, maybe because she is a long bed. I have talked with a lot of people about the brake conversion as mentioned most kits move your wheel anywhere from 3/4 to 1 inch wider
Betty :
'63 Fleetside Longbed
350 w/ 4 speed
CPP 3/5 drop with front sway bar.
RollinKaos is offline   Reply With Quote
Old 01-09-2011, 09:39 AM   #23
thunder71
thunder71's Avatar
i will take some pictures of this install & see how it all works out then i want to do my 66 long stepper
Old 01-15-2011, 09:56 AM   #24
thunder71
thunder71's Avatar
got my parts friday & will start install...super fast shipping from cali to NC...
Old 01-16-2011, 06:52 PM   #25
thunder71
thunder71's Avatar
got it installed & this is the after pictures....i likey
