01-07-2011, 12:35 PM | #1 |
Project Heaven in my 67!!!
Coy's fitment?
Does anyone know if the Coy C-5 rims have the same fitment issues that the Boss rims do? I am running a factory 72 C-10 Crossmember on my 67. I am planning on doing away with the 3" drop springs and going to a 1" drop spring and 2.5" drop spindles. I dont want to spend the big money on the Coys if they are not going to fit properly. Someone please help!
01-07-2011, 01:32 PM | #2 |
Re: Coy's fitment?
I sent them an e-mail, am looking at coys too, he said they will fit factory rotors, hd and cpp rotors need a spacer for the center cap. hope this helps.
71 chevy cheyenne lwb http://s321.photobucket.com/albums/n..._tab_my_albums Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote! |
01-07-2011, 01:44 PM | #3 |
Re: Coy's fitment?
01-07-2011, 05:15 PM | #4 |
Re: Coy's fitment?
I needed about 3/16'' worth of spacers for my Coys with a CPP spindle and disk brake kit. Could probably get by with an 1/8''. I think Im just going to chuck them up in the lathe and turn the end of the rotor down a hair.
68 lwb to swb Cummins swap in the works. I promise it will be cool someday. |
01-08-2011, 07:58 PM | #5 |
Re: Coy's fitment?
he didn't say how thick but they have the spacers or you could make some, i won't need them as i have stock rotors. you could call them at 801-356-2929.
01-08-2011, 08:12 PM | #6 | |
67-72 parts collector,…
Re: Coy's fitment?
The HD rotors are the 1.25" wide rotors that are on most 71-87 trucks. The LD,... or Light Duty rotors are the "odd ball" rotors. They were used on 1/2-ton trucks from 81-87,... but they are not the norm. The light Duty Rotors are the ones that don't require a spacer under the center cap. Board member Mcbassin was making them for a while,... but it looks like he is sold out. Look here at his thread: http://67-72chevytrucks.com/vboard/s...d.php?t=407944
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-08-2011 at 08:14 PM. |
01-09-2011, 05:43 PM | #7 |
Re: Coy's fitment?
Thanks for the info lolife, i will measure mine and see.
