Old 03-10-2003, 03:32 PM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
um, tires,wieght,springs,paint chips, and stupid owner
ok, heres the deal, i needed some more bace matierial for my parking spot, and around the yard. if you have it delivard, its about 90 bucks, 5 yard minumim. dont need that much. a yard will do.
so i own a truck right? lol. i brought my tarp to protect the bed. when he loaded the gravle, the end of the tarp slipped down and the rocks did this to my tailgate.#@%$#^% cheap ass paint., it chips easy. looks like ill be taking up painting again soon.
bumper got it too
how much wieght do you all think this gravle is?
i have never seen this truck actualy squat before~ im going to find a place tomorrow to weigh it, just cuz i wana know!
look at the springs! almost flat! wow, maybe they are getting old lol. or just alot of weight?
the overload bumper isnt close...
tires. i noticed a major differance with 25 extra pounds of air. at 40 pounds, it really was squirly. 65 not bad at all. the tires can hold 80, they say, but im kind of afraide to pump them up that high..? the weight rating is E. whats that mean anyway?
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 03-10-2003, 03:33 PM   #2
mtdave2
mtdave2's Avatar
dam those are big! lol ill try and fix that
69 k10 Suburban
Old 03-10-2003, 03:49 PM   #3
It is surprising how much that weighs. I was doing some work in my yard hauling some dirt and was getting ready to have the guy put in a second scoop when I looked at the scale. 1 loader full was a little over half a ton (bout 5/8), which already exceeded my 1/2 truck. Sure glad I didn't add the second scoop.
With what your hauling I wouldn't be surprised if it is pushing close ot a ton.
Old 03-10-2003, 04:05 PM   #4
72CustomCamper
Well, you have the right truck for it! Is that a Camper option package? I believe, that alone rates the truck a little more than the base 1500 lb.
as for the tires...my Suburban has D rated tires. I once loaded 3000 lb of landscape blocks on a pallete with the tires at max pressure. No problem!
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454
'93 K2500 Suburban, Old 454 (157K)
72CustomCamper is offline   Reply With Quote
Old 03-10-2003, 04:08 PM   #5
dat
The letter tire rating is a load rating (max weight), mostly heat disapation, sidewall strength and ply (4, 6 or 8 usually) combination.
The rating runs from A to F and on the auto tires (B class), there is usually a number load rating to break the class up even farther and is usually listed as part of the speed rating on the sidewall (like 88V).
B is rated to 35psi, C to 50psi, D to 65psi, and E to 80psi.
A's are small trailer tires. Most car and mini truck tires are B rated. Larger truck and SUV tires and larger trailers are C class and can handle more psi and higher temps for running under load.
An E class tire is a heavy trailer / heavy machinery tire (industrial apps and 5th wheel trailers is the only place I have ever seen them) and rated for 3000 per tire so technically you could load 12,000 lbs in your truck before the tires blew out!
'68 GMC 1500 LWB Fleetside w/350 & 3 spd (for now)
dat is offline   Reply With Quote
Old 03-10-2003, 04:29 PM   #6
cheyenne10
cheyenne10's Avatar
weight
I believe a cubic yard of concrete is around 2700 lbs. I've always figured a cubic yard of rock around 2000 lbs. Been there done that and never comfortable doing so. Watch the tire heat and hope your axles don't give out. Its also another issue to stop the beast. Keep most of the weight over the axle like in picture. I thin this will be a good reason for arma coating the bed on my clean daily driver some day.
Bob
cheyenne10 is offline   Reply With Quote
Old 03-10-2003, 06:53 PM   #7
jays68yak
jays68yak's Avatar
Ive had 3400 lbs of brick in the back of my 2500. Damn thing finally sat level for once.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 03-10-2003, 07:19 PM   #8
rangernsk
I was workin on a job last year and needed some gravel. Went down to the local rock quarry weighed in at 4225lbs. Went and got loaded with gravel and proceeded back to the scale to weigh out and pay. Weighed out at 10540 lbs. My C20 custom camper suprised me and the quarry workers. Lets do the math, thats 6315 lbs (about 3 tons) of gravel and the springs still had some arch to them. That was one of those proud days for me and my truck.
rangernsk is offline   Reply With Quote
Old 03-10-2003, 07:24 PM   #9
Stout72
Not my good side.
Stout72's Avatar
Is that an overload helper leaf atop the leaf spring stack? Looks like the shackles are missing.
So how much did the Longhorn squat?
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 03-10-2003, 08:10 PM   #10
Gee_Emm
Ouch, is that the original paint?
Gee_Emm is offline   Reply With Quote
Old 03-10-2003, 08:56 PM   #11
mtdave2
mtdave2's Avatar
there i posted an unloaded pict up there, so you can see the squat.
nope not orginal paint. it was repainted cuz of a vandel =(. with they guy would have paid for better paint! ugh
the overload spring is suposed to look like that.. its just starting to touch the bottom of the bed. i hand hear it hit when i drive over a speed bump! lol
thanks for all the info guys. im really wanting to know the weight.. ill find out before i unload it..
i know i had 1700 pounds in the back once. i didnt do anything but smooth out the ride. so this stuff must really be heavy!
watch the heat?? what do you mean by that?? heating up while driving? i know the tire said max load at 80 pounds cold. but how do you know how much the presure will go up? lol. thats the reason i dont want to put more than 65-70 in it. i hate beeing this dumb on things
69 k10 Suburban
Old 03-10-2003, 10:01 PM   #12
Bob Chayer
Is that the original rear bumper on your truck? I have the same one on my '72 3/4 ton 4x4.
Bob Chayer
71 3/4 ton 4X4 Suburban
Bob Chayer is offline   Reply With Quote
Old 03-10-2003, 11:24 PM   #13
mtdave2
mtdave2's Avatar
yep almost everything on that truck is orginal!
69 k10 Suburban
Old 03-11-2003, 01:50 AM   #14
cheyenne10
cheyenne10's Avatar
tire heat
My heat comment was around the overloading of tires. If the tires are really loaded up they tend to get a lot warmer causing the tire to weaken/break down. In theory with enough weight, higher speeds and a long dirve your rear tires could blow out or fall apart.
Bob
Old 03-11-2003, 05:43 AM   #15
Lippyp
English Chevy Owner
Lippyp's Avatar
So are you gonna unload it with a shovel or tie the tarp to something solid and lay some rubber down? bit like the old pulling the table cloth out from under the dishes trick!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 03-11-2003, 08:45 AM   #16
mrein3
mrein3's Avatar
The way tire ratings were explained to me by a dealer was as follows:
If you have 4 tires rated for 2000 pounds each you get 8000 pounds TOTAL. That includes the truck. My 4x4 is just shy of 5000 pounds so I have 3000 pounds left.
I have bought a load of rock twice. Both times I bought 1100 - 1200 pounds. I've never had a problem but then again I only have to drive just over the border into Wisconsin which is less than 10 miles from my place.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 03-11-2003, 09:37 AM   #17
Solver
Solver's Avatar
I have hauled quite a bit of gravel in the past and I would have to say that you have about 1 1/4 tons on there. Hope you don't plan on leaving it on to long. Older springs aren't use to that much flex. Also if you drive far with overload keep an eye on axle seals. Last time I kinda over did it and they started leaking.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 03-11-2003, 11:42 AM   #18
mtdave2
mtdave2's Avatar
Lippyp. thats the plan man, lol, but i think ill have to shovle some out first. its a bit heavy to pull out, the rope rips the tarp..
i have been driving around a bit with the load in there. its not that bad, the old girl handles it rather well. but she had one of those big ass compers on her back her whole life.
anyone know how much them old campers weighed?
69 k10 Suburban
Old 03-11-2003, 01:10 PM   #19
lpaine
lpaine's Avatar
I feel your pain..........
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
