305 out of a 77 Monza
Worth building? Got it for free
http://67-72chevytrucks.com/vboard/s...d.php?t=438550 ![]() ![]() 1994 Buick Roadmaster 1994 GMC Sonoma |
Re: 305 out of a 77 Monza
A 305 is a 305 is a 305.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
What is the difference between the 305 & 307 other then the displacement ?
307 has a larger bore/shorter stroke (if I remember correct
#5 | |
The bore and stroke configuration make the displacement different.
305 = 3.736" x 3.48" 307 = 3.875" x 3.25" Conventional wisdom says that the greater stroke of the 305 would produce more torque at the same RPM......and the 307 would rev quicker and make more horsepower at higher RPM. I wouldn't count on a huge difference in either of them in basically stock form, neither breathes particularly well. The early V8 Monzas were 262s, though by '77 it should have been a 305. I would be sure of what you have before you spend any money on it.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
I have a 307 in a 71 C-20 with 56k original, it sat for over 15 years. with fresh gas, new battery it started right up, uses no oil, does not smoke and you can't hardley hear it at idle ! Will never say anything bad about a 307
Small blocks from a Monza are somewhat different in some ways if I remember right from my Small block rebuilt book.
I'm thinking of the Oil filter mounting and perhaps engine mounts are machined odd compared to most small blocks. Something to be aware of.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. Last edited by toms68cst; 01-07-2011 at 06:39 PM. |
Looking back at my book it's the Chevy II that has some strange things about it. I don't see the Monza as having a small block.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
Cruzin
if you want build it, i have a 305 in my 86 monte carlo ss that has about 186,000+ on it runs great, uses no oil, and the only thing i have ever done to it was a intake gasket if it ever quits i will for sure rebuild it
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
The l69 motor in the 86 monte SS is a far cry from the normal 305. It has higher compression. larger cam[haha] and freer flowing heads with diferrent valve sizes compared to thier regular 305 brothers. I had one in a SS I bought new in 86 it would go for a 305. Could not make my friends belive that it was a stock 305 and most thougt I had slipped in a 350. Jim
