Old 01-07-2011, 06:57 PM   #1
Ericram
Screaming Edlebrock HELP!!
This one if for you edelbrock experts. I have a 350 engine with a 600cfm edelbrock and if I get on the gas good enough the carb will scream like hell as long as I keep my foot on gas. If driving below 60mph the carb is fine but once I get it going just over 60 the carb starts to scream. I've noticed it only started doing that recently as the weather got colder. What is it that I can do to eliminate the screaming sound period besides waiting for SPRING WEATHER!
Ericram is offline   Reply With Quote
Old 01-07-2011, 07:00 PM   #2
Ericram
Re: Screaming Edlebrock HELP!!
oh and the sound is pretty close to what it sounds like when belts are screaming/screeching. that's what I thought it was so when I went to check the tension I was suprised to see the belts were fine. thank you guys for your time!
Old 01-07-2011, 07:03 PM   #3
TheSeeker
Are you running a stock intake as well? Or an edelbrock intake? If you have an adapter it might have a vaccum leak. Mine did it when I first put it on because I didnt tighten it down enough. Screamed like a banshee
TheSeeker is offline   Reply With Quote
Old 01-07-2011, 09:45 PM   #4
dznucks
dznucks's Avatar
there is a vacuum bleed on the electric choke mechanism. I've had one whine at idle before.
dznucks is offline   Reply With Quote
Old 01-07-2011, 10:16 PM   #5
rob32472
Very simple solution. Remove, buy a new Holley and replace! Seriously had same issue and it was the electric choke as someone said earlier... good luck
rob32472 is offline   Reply With Quote
Old 01-07-2011, 10:53 PM   #6
72chevyk10
I built it
72chevyk10's Avatar
if it sounds like air sucking in thats the secondarys starting to open up. usually if its a vac. leak it'll run bad. or try spraying belt dressing on the belts, mine were squellin once and they seemed tight, but i sprayed em with the dressing and it stoped makin noise
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 01-08-2011, 12:56 AM   #7
Murphy IRE
Hmmmmm! I was told I was drinking that there isn't any vacuum on the choke. Mine was leaking and making a whistling noise. I made a temporay plug to end the leak and she ran better! I will have to have someone read this thread!
Murphy IRE is offline   Reply With Quote
Old 01-08-2011, 01:36 AM   #8
swamp rat
swamp rat's Avatar
What did you plug? where?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-08-2011, 07:08 AM   #9
dznucks
dznucks's Avatar
there is a vacuum bleed in the electric choke housing. its purpose is to keep the bi-metallic coil from over heating.
if you use a stethescope you can hear it. they can build up some gunk over time and make a more noticeable whistling noise. i am not sure it this is your problem though.
Old 01-08-2011, 02:09 PM   #10
bignbad
bignbad's Avatar
Very simple solution....Put a factory Q-jet on it
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline   Reply With Quote
Old 01-09-2011, 05:19 PM   #11
Ericram
@72chevyk10- it does sound like air sucking. You mentioned it could be the secondarys, is there something i would need to adjust/clean to stop it from happening? I have a stock intake w/adapter for carb.
Old 01-09-2011, 05:42 PM   #12
72chevyk10
I built it
72chevyk10's Avatar
does the engine otherwise run good? (besides the noise) like no stumbles, bogs.. etc.? i personaly like the noise so ive never tried to stop it i dont know if there is a way to or not.. mine isnt a "screaming air" sound its more of a "compressed air" type sound
and does it quiet down at wide open?
Old 01-09-2011, 05:45 PM   #13
72chevyk10
I built it
72chevyk10's Avatar
if it is the choke.. i didnt even know there was vacuum to it so it may be that too
