01-07-2011, 07:47 PM | #1 |
Removed clutch pedal, is brake pedal strong enough?
I'm swapping from a 3 speed to an auto, so I am taking out my clutch pedal. Does the brake pedal mount need be reinforced since I am taking the shaft out that runs through it's mounting point? The pic below helps for reference. Since I am removing #5 is there still enough structural integrity for the brake pedal to function properly.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224 |
01-07-2011, 08:34 PM | #2 |
Re: Removed clutch pedal, is brake pedal strong enough?
You'll be fine!
01-07-2011, 09:53 PM | #3 |
Mine has been that way for 8 years now and all is well.
Fuzzy |
01-07-2011, 09:57 PM | #4 |
Thanks for asking the question, did the same thing as you, and have been wondering awhile. Now I can sleep at night
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-07-2011, 10:26 PM | #5 |
if you have that bad of a problemo then get an auto set up from a auto truck
01-08-2011, 12:57 AM | #6 |
The pedal sets are the same. An auto set will have the provision to add a clutch pedal, it will not be a problem to have the clutch rod or pedal removed. The seperate setups did not start until 73 or so- auto trucks in those years have a wider brake pedal. In these trucks they were all the same and built on the same base. Hope this helps.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
01-08-2011, 01:09 AM | #7 | |
01-08-2011, 04:00 AM | #8 |
01-08-2011, 07:39 AM | #9 | |
Watch out for your cornhole !
Auto and standard trucks used the exact same parts. The standards simply got a clutch pedal inserted through the existing place in the assembly. I see guys selling "auto trans" pedal assemblies for elevated prices sometimes. It makes me want to go pull about a dozen pedal assemblies, pop the clutch pedal out of them and market them as "automatic" units to make some cash. Like he said, 73 began the different setups with the wider brake pedal on auto trucks.
01-08-2011, 11:42 AM | #10 |
Junior Member
This site is great, I learn something new everyday. I will have to tell my son, the mechanic, because he thought there was a difference.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
01-08-2011, 11:33 PM | #11 |
Thanks for all the help guys! I thought I would be fine, but I vaguely remembered a thread about this same topic and people saying it needed reinforcement. I couldnt find it in a search though. Thanks again for the help!
