![]() Join Date: Dec 2010
Getting my first C10. Couple questions.
I won an auction for a 70 C10 swb custom and will be getting it shipped in the next 2 weeks.
It is in very good shape so I will start driving from day one. In other words, I will not have body work to do right away. I wanted to know if there are any things I should do day one to make sure it is 'weather tight'? It is a Cali truck with all new weatherstripping. But I am not sure about for instance window channels and the seal where the top of the door skin meets the bottom of the window which I assume keeps most water from going inside the door. Is there anything I should do inside the door to make sure it stays rust free? (coating, etc.) Are there any other particular spots I should watch out for or protect in some way? I will be garaging it day and night. So hopefully rain will not be an issue. |
#2 | |
Re: Getting my first C10. Couple questions.
if i were you, id just make sure to give it a good thorough bath every few weeks, and drive it. its not like you really need to worry about road salt down there, which is what really is the killer of any vehicle.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains ![]() Quote:
![]() want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there |
![]() Join Date: Sep 2009
Think of all the places these trucks usually rust then think of what you can do to prevent it. GM's drain holes were very inadequate. Fenders doors etc don't rust from getting wet, they rust from staying wet i.e. dirt and debris settle in the bottom and the drain holes become stopped up so when it does get wet is stays wet for days and if you are in a wet climate it may never dry out. Wash and clean inside bottom of doors, front fenders, cab corners and flush rockers etc. Very important to remove cowl and remove old leaves etc then wash well. Remove sill plates and clean well, remove or fold back carpet and clean kick panels. Worst thing you can do is to assume because it is not rusty that it won't rust. Remember at one time they were all rust free.
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
Grandpa in the rustmobile...
Good info!
Maybe some 'rust reformer?' on these areas (they have it in a spraycan) or por 15 the areas?..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Young Gun
It sounds like you got it pretty well figured out but I Would fix any and all small places there is rust if there is any at all. That way it wont spread
Not to steal the thread but is there any way to seal off the cowl? Is there any purposes for the slits in the cowl?
1969 Chevy c20(Miss Hackjob) Last edited by treveiger; 01-08-2011 at 12:07 AM. |
They make aftermarket screens that fit under the cowl to keep trash out and retain original look.
#8 | |
The Older Generation
The screens that Paul mentioned work well too and are a LOT cheaper... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-08-2011 at 12:47 AM. |
Do the screens keep the rain out to? Ive seen them before and i liked the look of them.
1969 Chevy c20(Miss Hackjob) |
#10 | |
LockDoc
#11 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
69' Chevy Stepside
![]() Join Date: Mar 2008
I've got those nice screens on my cowl panel and they work awesome! I would definitely recommend them on any truck restored or not.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
#13 |
but the salt air in florida kills things from the top down compared to the rust belt where things rust from the ground up
#14 |
I appreciate all the suggestions. It helps.
The truck I got is a heater only truck so I will be immediately adding a a/c kit. Florida summers are brutal! By the way, I am still trying to find threads that talk about pro's and cons of each companies kit so if you know of a thread, feel free to point me there. The screens sound like a plan. I may eventually smooth it but screen will help for now. |
#15 | |
LockDoc
#16 |
Do you know of the filled cowels are avalable for purchase anywhere? Thanks for the info!
#17 |
Interested to!!!
1969 Chevy c20(Miss Hackjob) Last edited by treveiger; 01-08-2011 at 06:58 PM. |
