Old 01-07-2011, 10:52 PM   #1
Arky
Red face 85 Tilt steering wheel pivot pin
Hi all, while trying to fix my wobbly steering, I managed to break off the steering wheel pivot pin puller, in the pivot pin itself. Could anyone tell me if there is another way to pull the pin ? Its on the ignition side, so access seems limited. Is this a part that I have to go to a dealership (stealership)? I can't seem to find it anywhere. Please help. Thanks.
Arky is offline   Reply With Quote
Old 01-08-2011, 04:47 PM   #2
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: 85 Tilt steering wheel pivot pin
Could you post a picture? I think I know what you're talking about but I want to be sure. I used a bolt/slide hammer to pull the pins on mine, you can make a nice slide hammer using vise grips if you have anything to grab on to. I've found this to be a pretty handy reference.
http://www.fiero.nl/forum/Forum2/HTML/088020.html
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 01-08-2011, 07:58 PM   #3
54Caddy
GM Addicted
54Caddy's Avatar
i used a screw when i did mine. What i did was set a small socket against the collumn. Thread the screw into the pin and with two nuts on the screw is i turned the nuts and used the socket and screw as a puller. It took a while but worked great. Id like to get the tool for this but where can it be purchased at?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 01-08-2011, 10:24 PM   #4
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Did you remove the tension spring? It is under the round cap in the center bottom of the knuckle. If not the pins will not come out. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-11-2011, 02:30 AM   #5
Arky
Cool Re: 85 Tilt steering wheel pivot pin
Hi All, thanks for the replies. I did manage to get the pin out but kinda had to destroy it in the process. I had to drill out the broken piece of the pin puller, well, as much as I could. Then I used an extractor tool to yank the pin out enough to get a vise grip on it. And ta-da, one unthreadable pivot pin.
Thanks 85gmcguy, I found that site very helpful. 54caddy, your made up tool seems better than the "POS" pivot pin puller that I purchased from O'Riellys for like $20. The screw part snapped off in the pivot pin.Big Port Jimmy 6, yes I did. I need to find another set of pivot pins, hopefully not at a stealership. Arky
