Old 02-28-2002, 11:37 PM   #1
BillyBob84K5
Angry JBA shorties eating wires
I've had JBA shorties on my truck for about a year now. And, recently, they've been eating the #3 cylinder wire, and the wire acrs to the header. I've been through about 3 sets of wires, and I'm going to be using some boot protectors and some heli-core multiangle MSD wires. I need to know how or what I can use to stop these wires and boots from melting and arcing, since the straight boot is almost right ontop of the header tube.
BillyBob84K5 is offline   Reply With Quote
Old 03-01-2002, 07:17 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Red face
BillyBob84K5,
Try using some 90 degree wires. Use wire looms too. I've had not used headers before but I think the two options should help.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-01-2002, 12:08 PM   #3
low 84
low 84's Avatar
Wink
Hey Billybob84k5,
What is the part number for those headers and where did you get them?
I'm looking for a set of shorties for my 84 siverado cause its lowered.
Are they ceramic coated and how much $$$
thanks for any help
Pot holes are my enemy
'84 1\2 ton swb, 350 5\7 drop
just sold '64 1\2 ton
4\4 drop with built 350 (my toy)
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-04-2002, 07:30 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
Post
I suggest running them under the headers. It may not look as cool but it will stop the burning wires.
Mike
1985 Chevy C-10
Mike's 73-87 Chevy Pickup Site
[This message has been edited by swervin ervin (edited March 04, 2002).]
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 03-04-2002, 11:21 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Never had a problem with 90 degree boots and looms on my rig. I would think that routing them under the header would cause the rubber to get brittle quicker from all the heat...I could be wrong, just something I have always suspected.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-05-2002, 06:03 PM   #6
swervin ervin
Post
Nope, not the case. Most shorty headers have the tubes built in a quirky way to where it makes it tough to keep the boots/wires off of them. I had no choice with my Edelbrock TES headers because the A.I.R. tubes were in the way on top. Besides that, heat rises for the most part and with my headers being ceramic coated they run cooler anyway. I bad wanted my wires over the top with some nice wire looms, but now after mine being under, I like it better. It sure is nice not having to remove wires when you need to work on the top.
Mike
1985 Chevy C-10
Mike's 73-87 Chevy Pickup Garage
Mike
1985 Chevy C-10
Old 03-06-2002, 07:08 AM   #7
gchemist
gchemist's Avatar
Talking
I'm just drooling over the engine pics. Can't wait to get mine looking like y'alls.
Gerardo
1983 Custom Truck
Old 03-08-2002, 11:37 AM   #8
Chevyman69
Vortec 350's Suck
Post
On my 92 I have Edelbrock 6656 TES's, but without any emission crap like Swervin has to deal with. I found that using the factory looms and wires works the best, 90 degree boots and loomed as stock my wires never get anywhere near the primary tubes. BTW very nice looking engines guys, especially with Swervin cause usually all that emmission stuff looks terrible, but that looks awesome.
69 CST 10, 402, steel crank, heavy rods, Federal Mogul Forged Pistons, 9.9:1 compression, polished ported 781 heads 2.19/1.88 manley stainless valves, Crane Powermax Hydraulic roller 288/296 and .587,.610 lift, hardened pushrods, Crane Roller Rockers, Weiand Action Plus, 750CFM Rochester QJET, MSD HEI, MSD 8MM Wires, Dynomax Ceramic coated headers, should be about 500 H.P. 700R4 2500 stall, pretty nasty shift kit, 373 Auburn Pro Series Posi, buckets/console air/tilt/tach 4wheel discs
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, loaded, 350 Accel filter/cap/rotor/coil/AC Delco wires/AC Delco RapidFire plugs, Edelbrock intake and headers, 180 degree thermostat, Hypertech Thermomaster Chip, true duals 700R4 with B@M Shift Kit for now!
69 Chev CST 10 reg cab lwb
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, K.I.A 7:51 AM 04/22/03
Will be resurrected
Chevyman69 is offline   Reply With Quote
Old 03-09-2002, 01:34 PM   #9
Longhorn Man
Post
I always forget about the emissions you guys deal with, I am actually into the '67 - '72 trucks. What little crap they have, hits the floor as soon as I get them(if it hasn't been done already).
Thanks every one!
