how can i repair my caved in hood
ok i have a rust free all the way gmc hood.theres very little surface rust just behind the turn signals my only problem with the hood is that on top of it is caved in how can i make the repair to make it cave out to its orignal shape im still ganna decide if i want to to put the chevy hood that has a scoop on it or if i should i leave the gmc hood if i can fix this problem then im ganna put the scoop hood to see how it looks if i dont like it ill just leave the gmc hood and hopefully u guys can help me out in fixing this problem ill post some pictures hopefully this week or next week to see what looks and whats no good.
Thank,Marco 1965 ![]() |
Re: how can i repair my caved in hood
hard to say without a pic!
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
Senior Enthusiast
If it's the typical dip in the center you can fix it the way I did mine. I just picked up a couple extra sets of hood braces at the junk yard and added rubber strapping to “push” the low spot up where it belongs. The braces are very light and have had no effect on the springs holding the hood open. Lack of suitable bracing is why these things droop in the first place. If it's caved in enough to stretch the metal it's going to require shrinking to repair, which requires a torch and some talent/experience.
![]() Last edited by markeb01; 01-08-2011 at 04:13 AM. |
Old 1966 GMC:
I have the same issue. Here is the best plan for repair that I have found. See Phil V's response in this discussion: http://autobodystore.com/forum/showt...ht=impala+hood Regards, Steve New Orleans |
I had a dip in my hood. Not sure if it is to the same degree, but I grabbed a benzo and heated it lightly and Pop! no more dent. Lol
Not saying that's a god idea for a painted hood, but mine was down to bare metal at that stage.
Cheers David 66 LWB Fleet (on hold) 64 LWB Fleet (daily driver) 65 SWB Fleet (almost finished as a driver) 64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck) Nothing worth doing, is easy. |
it is the dip in the center ur talking about markeb01 really hate to use a torch on the hood not looking into messing this one up. really liked the way u fixed ur hood.need some more info on that one i perferd putting brace and rubber then pulling out the torch
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I'm hoping to get by with one down the middle.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Senior Enthusiast
Depending on the size of the bow in the surface, one down the middle might well solve the problem. I just used a bunch because I had a pile of them and they weigh very little.
Is that chain you have hanging from your hood kind of a safety catch?
![]() Join Date: May 2007
probably a lock chain so no one steals the battery.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#11 | |
Senior Enthusiast
http://67-72chevytrucks.com/vboard/s...ight=hood+lock |
