Old 01-08-2011, 02:04 AM   #1
8door
Not too old to learn
Plug wire layout ?
Finally getting serious about my 68 build. Got engine/transmission in and cab
painted and set.
I need your pictures of what different styles of routing plug wires.
My engine is a new 350 crate with the wire brackets attached to tops of
vale covers.
Not sure I want wires over valve covers, but wanted to see what you all have done.
I also have a set of earlier valve covers without the brackets, so I can go either way.
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 01-08-2011, 08:54 AM   #2
OhioDan
OhioDan's Avatar
Re: Plug wire layout ?
Here's how I did mine, and how it looks. Used HEI plug wires for a 75 Vette, smallblock. Bought them at NAPA. Sorry, don't have the part #. Routed them the same as first pic, only they're for HEI, and not standard ignition. Please pay no attention to the rusted exhaust mainifolds or the rusted master cyl. Those are being taken care of. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 01-08-2011, 09:21 AM   #3
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Very Clean Looking Dan. I Like it.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-08-2011, 09:49 AM   #4
OhioDan
OhioDan's Avatar
Thumbs up Re: Plug wire layout ?
Thank you.
Old 01-08-2011, 03:24 PM   #5
8door
Looks good Dan.
Are those preformed wires ? or did you make them ?
They are longer than over top of valve cover right ?
Old 01-08-2011, 03:32 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
About 75 corvette wires he said..
I need to do this, that looks CLEAN
John
1999 Toyota Tacoma 4x4
Old 01-08-2011, 04:14 PM   #7
8door
Pays to retain what is printed.ops:
Any one else have pics of over the top ?
Old 01-08-2011, 04:31 PM   #8
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
I'm a big fan of running the plug wires out the back and under the headers.
It saves me time to run the rack for a quick adjustments and makes every thing look clean.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 01-08-2011, 04:38 PM   #9
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Just saw a summit add while watching Trucks this morning and now they have a dizzy cap that puts the wires in the correct place so theres no crossing them near the dizzy..I'm going to look into it my self.............
Hottrucks is offline   Reply With Quote
Old 01-08-2011, 04:49 PM   #10
8door
Hummmm, beginning to like the clean look.
Mine has an HEI also, with stock ram horn manifolds.
Old 01-08-2011, 07:25 PM   #11
grs
Where can I buy the rear supports for the wires? And the wire retainers to go in the supports?
grs is offline   Reply With Quote
Old 01-08-2011, 09:01 PM   #12
JimKshortstep4x4
This is what I do with the plug wires on the HEI's. The wires are separated using wire ties. These are Standard PN 6870 wires with straight boots.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-09-2011, 12:05 AM   #13
oldblue1968chevy
Under the ram horsn ftw
John
Old 01-09-2011, 01:26 AM   #14
jakeblues652
jakeblues652's Avatar
i would also like to know what looms you're using for this back and around deal. looks neat. maybe i'll need to do it.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 01-09-2011, 01:48 AM   #15
8door
Jim
The part number is GM ?
Looks like a straight boot to plug works best.
I can't tell from pic, is there a stand off support away from engine ?
Thanks for the info Jim.
Old 01-09-2011, 07:09 AM   #16
OhioDan
OhioDan's Avatar
Actually, there's 3 different plugwire stands IIRC? I got mine from GMCPaul. I'm sure most, if not all of the vendors on the board would have them? There's 1 on each side at the rear, 1 down by the oilpan on each side, and then 1 up by the front plugs on either side. (6 total) Hardest part is getting up the gumption to do it. Hope this helps?
Old 01-09-2011, 10:27 AM   #17
grs
Hey ohiodan, I went to gmcpaul's site, but I could not find the wires stands. Do you have the part number? Thanks again.
Old 01-09-2011, 11:27 AM   #18
my67c20
Check out this thread http://67-72chevytrucks.com/vboard/s...d.php?t=295089
or this one.
http://www.67-72chevytrucks.com/vboa...d.php?t=165181
my67c20 is offline   Reply With Quote
Old 01-09-2011, 11:31 AM   #19
chevy71super
The hidden wires looks really good. I wonder if it will work with a 4X4. The engine is so close to the firewall. Doug
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 01-09-2011, 02:52 PM   #20
Gus350
68 C 10
Gus350's Avatar
Dan
What kind to alternator bracket is that on top attached to the water pump....I like how clean it looks
Thanks Kev
Gus350 is offline   Reply With Quote
Old 01-12-2011, 03:43 PM   #21
8door
Bought a wire set from Napa today, as OhioDan recommended. Under manifold type and attachment to the HEI.
Now where do I find rear support separators ???
Old 01-12-2011, 04:06 PM   #22
oldblue1968chevy
Bump for separators! This is CLEAN
John
Old 01-15-2011, 10:59 AM   #23
OhioDan
OhioDan's Avatar
No, I do not have the part #'s for the plug wire brackets. I called one day and talked to someone working there,(not Paul) and told him what I was looking for.(stock plug wire stands) He found exactly what I needed.
Old 01-15-2011, 11:13 AM   #24
OhioDan
OhioDan's Avatar
Originally Posted by Gus350 View Post
Dan
Thanks Kev
Not sure what year/model it is for, but it is GM. And it is a Chevrolet. Originally, there was a black one from an earlier rebuild, and it came back at an angle from up around the alt. jam bolt, back to a bolt/stud on the intake. But I liked the chrome one cause it looked a little sportier and bought it. It was at some speed shop. It's not chrome original equip.
