Pictures
Here are the pics of my truck. Now it has a 6 inch home made lift and is completely unstable. I have a friend that is gonna fix the whole suspension to a 4 inch and do it so its right and safe
2004 Silverado Crewcab (Dark Spiral Gray) |
It followed me home?
Re: Pictures
Nice truck. Any pics of the suspension? I love seeing that home made stuff
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Re: Pictures
unstable??
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Re: Pictures
Yes, well there are stacked blocks on the rear with the wrong U BOLTS, they used the square Ubolts instead of the round ones that belongs on there. The front, they added springs to the evidently rearched original springs again with the square Ubolts. The passengerside has a gap between the spring perch and spring pack, that wont close. and the steering gear box is bad as is the upper and lower ball joints on both sides. Other than that
![]() Join Date: May 2009
Re: Pictures
Check for frame cracks at the steering box while you are in there. Check with ORD, the make a plate to strengthen the area, and a steering box brace. Nice looking truck, I had a black 82 3/4 ton.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
Re: Pictures
The frame is still good and strong no cracks. This thing has the HYDRO-ASSIST steering and brakes so I dont have to have a brake booster. sure glad of that, I just have to make sure I use good belts on it.
Re: Pictures
I like it!!!!!!! 4 inch safe lift and tight front end will be much better
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed ![]() ![]() |
Re: Pictures
Thats what is going on it, next week,
Re: Pictures
Well its fixed and rides SOOOO much better and steers normal. I need to ditch the 315's on here and get some 285's (33) also need to do something with the rims, makes the truck look bad. Now working on the wiring to get the original gauges working and such, then start on the interior, kind ugly right now and seat to bouncy. Gonna see if I can get the seat recusioned with foam or something. Cant seem to find a seat from a newer (88+ ) year
