Old 01-08-2011, 12:25 PM   #1
Ironhorse
Ironhorse's Avatar
Open a Tool Box Dr.-No Latch/No Lock/No Key
Since my '71 4x4 doesn't have the tool box option I don't have a lot of experience with trying to open with doing damage to the door. Have tried to "lift" the tabs which remain by hand with no luck. Like I said, don't want to get nasty and just pry bar it open. Not sure if the door has to much rust to be saved but will offer it on the parts board when I can get it from the truck. Any one with thoughts on how to accomplish this without destroying the door in the process?
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 01-08-2011, 12:59 PM   #2
Steve Hafner
Steve Hafner's Avatar
Re: Open a Tool Box Dr.-No Latch/No Lock/No Key
Don't give up on the rust problem - mine is just about that bad too and it's getting restored. You just have to find a good body man like I did.
Life is short . . . we only have, right now.
My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526
Steve Hafner is offline   Reply With Quote
Old 01-08-2011, 01:21 PM   #3
cdowns
cdowns's Avatar
i'd take a very thin stip of sheet metal and try sliding it into the top of the door and work it accross to where its being held closed
or if the box of the toolbox is shot i'd pungh a hole thru it and try accessing the door from the rear
Old 01-08-2011, 01:31 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
There should be a "catch" behind where the handle is. It needs to be pulled down for the latch to releice the striker. If you cant see the little catch, then you need to find a way to pull the latch bolt down. (Mabe weld something to it?) (They latch a lot like a Glove Box.) WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-08-2011, 02:22 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Theres only so many GM keys right? Couldnt you just try to find the key.?
never mind, i was lookiing at the blue box..lol
John
1999 Toyota Tacoma 4x4
Old 01-08-2011, 02:41 PM   #6
jaros44sr
jaros44sr's Avatar
oh no! another 'is it open yet thread' Good luck, but I have no answers
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-08-2011, 04:28 PM   #7
69sixpackbee
By the looks of that door it wont be long before it opens itself!
LOL
69sixpackbee is offline   Reply With Quote
Old 01-08-2011, 05:29 PM   #8
matthew20061
69' Chevy Stepside
matthew20061's Avatar
The previous owner of my other truck with the tool box deiced it might be a good idea to use a pry bar and bend the door out to see what was inside. All it did was bend the door... Then I came along used a small bar to move the locked lock out of the way and pulled the handle and messed with the handle a lot and it finally popped open. Never seen inside one but it had what looked like the factory jack and some ancient belts inside. Then we closed it and now it won't open! LOL
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-08-2011, 08:43 PM   #9
Ironhorse
Ironhorse's Avatar
Well tried using a couple putty knifes this afternoon with no luck. Slid them between the body and the door opening pushing down. There seems to be a very short "tab" protuding down thru the backside of the latch housing or where the latch "should" be. Will try that tomorrow using a pair of vise grips and "gently" pull. Gotta' get it open before I can try removing the door and box.
Wellington, Ks
Old 01-08-2011, 09:03 PM   #10
You probably can't grab the latch bolt through the lock hole. I'd sacrifice the fiberglass box and get to the backside of the door. More compartments survived than doors.
