Old 01-08-2011, 03:16 PM   #1
nathansmith15
lowering questions
i have an 83 2wd and i want it lowered . . .im planning on cutting the front coils and im thinkin bout a flip kit for the rear . . . i was wandering if there were any problems to deal with when cutting the frame . . . if anybody has any advice id like some input . . . it also has a 412 sbc in it u dnt think that much power will hurt it would it lol like twisting the frame?
nathansmith15 is offline   Reply With Quote
Old 01-08-2011, 05:44 PM   #2
lilpoindexter
lilpoindexter's Avatar
Re: lowering questions
I have a flip kit, with no notch...just a little bumpstop.
I didn't want to cut the frame either.
lilpoindexter is offline   Reply With Quote
Old 01-08-2011, 06:30 PM   #3
3r!c84
Badass
3r!c84's Avatar
do it the right way and get drop spindles. cutting the coils you will never get the alignment right and it will allways wear front tires.. and the back. the flip kit will hold the power. but dont cut the frame..
btw we need a pic of this truck
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-08-2011, 06:57 PM   #4
jokerswild
^^^^ I cut my coil and use drop spindles, i use offset upper control arm shafts and i have never had a problem with tire wear or alignment.
jokerswild is offline   Reply With Quote
Old 01-08-2011, 09:56 PM   #5
3r!c84
Badass
3r!c84's Avatar
Yes drop spindle and cutting coils. I have the same thing on my truck .. I was talking about getting 3-4 inch drop from just citing coils with stock spindles you will have problems
-00 Saturn 5spd
1/4:13:90
Old 01-12-2011, 12:59 PM   #6
198ChevyGuy
I personally wouldnt mind a lower stance, I just dont know the costs for it, So far parts are lil more expensive than my 76 f100, About how much does it dent the pocket book? Also Does it give a more agressive look for the lwb?
198ChevyGuy is offline   Reply With Quote
Old 01-12-2011, 01:07 PM   #7
3r!c84
Badass
3r!c84's Avatar
hers a ball park pricing.
3inch drop spindles. 280
flipkit no C notch.80
cutting stock springs.free
alignment when your done. 80
your time. priceless
-00 Saturn 5spd
1/4:13:90
Old 01-12-2011, 01:17 PM   #8
198ChevyGuy
Heh, i charge 56 per hour my times not free, but can you tell me wtf is the obsession with those ugly 20's doesn't anyone believe in laying rubber or having rubber to lay?
Old 01-12-2011, 01:59 PM   #9
7T2
Active Member
7T2's Avatar
If you are going to cut the coils, at least do it with a cut-off wheel while all of the spring except what you are cutting off is in a bucket of wet sand or water. If you just lop off a couple coils with a torch you will destroy the "springiness" of the spring and have a super harsh ride. You'd be surprised how many people don't give this a thought. It's going to ride rough enough with properly cut coils, doing it the wrong way gives you the same ride as putting a length of iron pipe in there.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 01-12-2011, 02:10 PM   #10
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I cut 1 coil from the front of my truck 1coil=2" drop
Didnt notice any ride change I did it with a cutoff wheel on a air grinder
John
1999 Toyota Tacoma 4x4
c-notch lowering
