Old 03-10-2003, 07:14 PM   #1
hiddingout
swapping rear ends
if anyone knows if i can do this it would be very helpful. I own a 1989 chevy 3/4 350 6 lug with a bad rear end in it. I can buy a1989 GMC 3/4 350 with 8 lug. i was wondering if they interchangable. I was going to replace the whole axle. any advice would be apprecaited. thanks
hiddingout is offline   Reply With Quote
Old 03-10-2003, 08:35 PM   #2
special70gmc
special70gmc's Avatar
wouldnt see why not unless the suspention has different mounts.
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 03-11-2003, 03:08 AM   #3
1969 GMC
1969 GMC's Avatar
If you swap in the 8-lug rear, then you will have 2 different wheels to worry about. If you have a spare for the 6-lug, then the 8-lug tire will blow up 100 miles from home. And vice versa. And if you have a spare for each, you probably won't get any flats.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-11-2003, 06:28 AM   #4
hiddingout
Here something that I omited from my Original post. Both trucks are 4 x 4s.I think this is why I will have a problem switching them. any advice helpful. I never thought about the 2 spare thing thanks1969 gmc.
Old 03-11-2003, 11:56 AM   #5
matt67350
matt67350's Avatar
Measure the spring saddles on both axels, check the brake lines to see if they match, look at the pinion yokes to see if they are the same, and the e-brake cables are they the same, and thats just the start. good luck
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 03-14-2003, 12:43 PM   #6
crazy4chevs
crazy4chevs's Avatar
If its a 4x4 make sure both rears have the same gearing so the new one will work right with the front gears. Also to get around having to have 2 spares you could change the front axle hubs so the front would have 8lugs too.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
