Old 01-08-2011, 08:09 PM   #1
mwooten92
mwooten92's Avatar
Exclamation could some1 tell me where this plugs into?
i have a 1985 chevy truck and this wire comes up from the transmission and cant find where it plugs into. we think it is the neutral safety switch. does some1 recognize it? or know where it plugs into?
85 C-10 ShortBoxChevy!
Build Thread of my 85' C-10
http://67-72chevytrucks.com/vboard/s...d.php?t=367919
mwooten92 is offline   Reply With Quote
Old 01-08-2011, 08:51 PM   #2
joe231
joe231's Avatar
Re: could some1 tell me where this plugs into?
I know that some of the TH350C transmissions have an extra 2 wire plug on the passenger side of the trans......
what trans are you running?
CHEVY ONLY
Old 01-08-2011, 08:56 PM   #3
mwooten92
mwooten92's Avatar
its the 350 turbo transmission as far as we know. there is a switch on both sides. passenger and driver side. they come up from the transmission and tie in and make up this pigtail.
Old 01-08-2011, 09:01 PM   #4
joe231
joe231's Avatar
is the driver side a 4 wire plug?
you don't need to hook it up if it is a TH350C. all it does is lock the torque converter.
I did a ton of research on these when I had my '80 shortbed. you can leave it unpluugged and it will work just like a regular th350. The converter locking will drop your highway RPM @ 300 RPM, so not a big gain.
If you are wanting to hook it up, you should have a vacuum switch mounted to the firewall somewhere above the brake booster
CHEVY ONLY
Old 01-08-2011, 09:02 PM   #5
slb1985
slb1985's Avatar
i dont think its the neutral saftey switch i think that swich is contained in your colum and on stops power to your starter, not from the trany itself. if im wrong someone correct me
1987 R10 Silverado - Rusty But trusty Daily
1984 C10 Custom Deluxe - Newest Project
slb1985 is offline   Reply With Quote
Old 01-08-2011, 09:12 PM   #6
mwooten92
mwooten92's Avatar
hmm. alright well thx for some info on it. were doing a motor swap and plugging all the wires all back up and ran across this plug dangling on top of the trans
