Old 01-08-2011, 08:23 PM   #1
dixietruck71
dixietruck71's Avatar
What should i do to this truck
Im new to this forum and was wanting to get advise on what direction to go with my build. the truck is a 71 gmc sierra grande. it was my grandfathers truck and he bought it new. gave it to me for my 14th birthday and i did alot of work to it. now im 30 years old and decided its time to start driving it again, beings it was my highschool ride, it sat for the last 6 years. any how shes all stock for the most part. 350 4 speed 2 wheel stock suspension. all i know is that i want to put all the upper and lower trim back on and lower it but i cant decide how much. mabe a 4-6. any ideas would be great.
dixietruck71 is offline   Reply With Quote
Old 01-08-2011, 08:27 PM   #2
rogergodding
rogergodding's Avatar
Re: What should i do to this truck
Welcome!! Does it have coils or leaf springs in the back?
rogergodding is offline   Reply With Quote
Old 01-08-2011, 08:29 PM   #3
dixietruck71
it has leaf rear suspension. i was thinking of putting the axle on top of the springs for a cheep rear drop till i have the extra funds to go with a bag system in the rear.
I also have a set of the old style slot mag wheels for it
Old 01-08-2011, 08:32 PM   #4
68lwb292
Ex-Minitrucker
68lwb292's Avatar
Clean it up, tune it up, 4/6 drop, maybe some new wheels, and drive the heck out of it.
68 C10 LWB 292 4spd
68 C10 LWB 250 3spd
68lwb292 is offline   Reply With Quote
Old 01-08-2011, 08:53 PM   #5
4" drop in front an axle flip or lowering shackles. If you have slots,that's good. I think it would look good with white smoothies and baby moons for some reason...with a white top
Old 01-08-2011, 08:56 PM   #6
rogergodding
Never done the axle flip thing, some guys on here recommend it. I have Early Classic drop leafs that I am about to install, if you combine them with the shackles that EC also sells you can get about a 5.5" drop. Some guys might tell you to remove a leaf from what you already have, that is how mine currently sits and it bottoms out easily.
Old 01-08-2011, 09:03 PM   #7
treveiger
treveiger's Avatar
Leave it as it is, put some old rallys on it and clean it up and fix the rust spots on it so it stays in good condition for a long time!
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-08-2011, 09:06 PM   #8
dixietruck71
i definetly want to do the white top. mabe white center too.
I am afraid to pull a leaf from the rear because it has bad axle wrap/wheel hop as it is. pulling a leaf will just make it worse.
i do need a core support for it. all i find are listed for chevy not gmc. are they the same?
Old 01-08-2011, 09:07 PM   #9
dixietruck71
their is no rust or rot. the paint is from 2002
Old 01-08-2011, 09:15 PM   #10
Spoof
Spoof's Avatar
Hi dixietruck71,
My truck was almost like yours, but brown and a 3/4 ton. I added the deluxe two tone paint and trim and I'm really happy with it ( still in the shop )
I always use my example as a cautionary tale, don't rip it all apart unless you're 100% ready with the time and money to put it back together as you'd like. I sounds as if you have the right idea.
Leaf springs can be de-sprung for a cheap drop, can't say if would suit you. I ended up swapping to a 1/2 ton frame with rear coils.
You will need a GMC core support since the GMC double headlights are required, you can weld the GMC headlight mounts onto a chev support. That's what I did.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 01-08-2011, 09:18 PM   #11
71sierragrande
Petroleum User
71sierragrande's Avatar
I would say put the slots on, leave the trim off cuz it hides the beautiful lines of this body style. Oh yeah, spoof is right, I forgot about the headlights.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 01-08-2011, 10:15 PM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You might also look at a 5 speed OD conversion to get a bit better fuel milage and hiway manners.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-08-2011, 11:12 PM   #13
dixietruck71
i have just started to research the 5 speed conversions but am not getting verry far. i was thinking a nv4500 but was told that a 5 speed from a 2002ish chevy is a better one to go with but i cant figure out what model that is. origionally i was going to go with the borg warner wc t5 but after braking a few with a inline 6 i decided that i dont want to waste my time.
Old 01-08-2011, 11:17 PM   #14
dixietruck71
right now my tires are 255/70/15. i want to go to a 60 series tire my slot mags are 15x7s how wide can i go.
Old 01-09-2011, 12:08 AM   #15
VA72C10
VA72C10
VA72C10's Avatar
4/6 and trim sounds great!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-09-2011, 03:09 AM   #16
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I think 4/6 or 5/7 drop would look good. I thought mine was axle wrapping too, then I just checked the carrier bearing and its loose so I'm gonna fix that and see if it helps out any, you might want to look at yours (mine is a 3/4 ton with leaves, it had 10 leaves originally but I took out 4 to get some drop). If you want to drop it with leaves you should to the flip, its cheap and will retain the ride you have now. I'm in the process of swapping to coils, it cost me $185 for the rear, $40 for the trailing arms and springs. If you are planning on bagging it, the coil setup makes it a no-brainer.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-09-2011, 03:31 AM   #17
YBNORML
YBNORML's Avatar
Nice truck man! It all depends on what you want to use the truck for. If it was mine I would drop it 5/7 put some 18/20 inch wheels on it and drive the crap out of it.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-09-2011, 04:26 AM   #18
treveiger
treveiger's Avatar
If you wanted you could get a overdrive unit from gear vendors if you wanted a simple overdrive and keep your stock tranny. I honeslt wouldnt worry about changing to much because the more you do the longer youll be working on it rather than enjoying it. But in the end what you want it what you should do.
Old 01-09-2011, 01:55 PM   #19
Kokomoooo
Do what your heart tells you to do. I'm building my Longhorn with all of the goodies that I would want in a new truck, so thus, it is my new truck. Having lost my butt on new trucks, I now know its better to put money into a vehicle that has a value thats going up, instead of a vehicle that loses 25% just as soon as you sign on that line!!
Kokomoooo is offline   Reply With Quote
Old 01-09-2011, 02:18 PM   #20
LockDoc
The Older Generation
LockDoc's Avatar
Here are a couple of threads on an OD swap. Lots of good info.
http://67-72chevytrucks.com/vboard/s...d.php?t=438224
http://67-72chevytrucks.com/vboard/s...t-5+trans+swap
See my post #12 in the second thread...
LockDoc
Leon
Old 01-09-2011, 03:06 PM   #21
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have a '72 GMC Super Custom. The original owner painted the top black instead of white. It has the original sea green body color. Looks "different". I thought I wouldn't like it at first, but it grew on me, and everybody always comments on it.
The core supports are not available for the GMC's. But you can get a 67-68 Chevy core support, remove the single headlight buckets, and tack weld the GMC dual headlight buckets onto it. I'm assuming yours is toast under the battery tray (like all of these trucks). I just did a little fab work on mine and used my stock core support. It was completely rotten under the battery tray... had to replace the inner fender too.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-09-2011, 04:18 PM   #22
RCbowtie69
RCbowtie69's Avatar
nice project, U got a nice truck to start with,
RCbowtie69 is offline   Reply With Quote
Old 01-09-2011, 04:22 PM   #23
dixietruck71
thanks for all the comments and advice. i have just finally decided not to make it a short bed. Now just need to start buying parts. i also started using it as my daily driver last week. forgot how fun it was to drive. and the smell of gass when i take a hard right turn is sweet!!!
71 gme Sierra Grande lwb.
68 Rambler American 2 door
75 jeep cj5
Old 01-09-2011, 04:30 PM   #24
treveiger
treveiger's Avatar
Glad to hear your keeping her long. The smell of gas in the cab are what makes these truck fun to drive i love the smell of the gas, brings back memories of when i was younger in my dads 71
Old 01-09-2011, 04:51 PM   #25
swamp rat
swamp rat's Avatar
Na! I think you should part it out, i'll take the seat! Be there in a couple hours.....
Seriously though thats a sweet truck! good luck with it. and welcome to the forum from Spanaway!
If ya do run a cross a good seat for one of these trucks shoot me a pm..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
