Old 01-08-2011, 08:51 PM   #1
Buick455
Greaseable rear shackles
Instead of buying new rear shackles with rubber bushings for my 87 3/4 ton 4x4 GMC I purchased poly bushings from Energy Suspension (Part Number: 3.2126, Eye Bushings 1-3/8 Inch Eye, Price: $13.99 for 1 set of 4). After pressing out the original bushings (which are molded into the shackle) I drilled and tapped them for a grease Zerk (1/4-28). I then painted the parts black and installed the Zerk's with a stainless steel washer under the Zerk head so the Zerk would not protrude into the ID of the bushing bore. I used blue loctite on the Zerk threads.
I also drilled a hole into the bushing tube but is not really needed as I want the poly bushings to slide in the bore of the shackle and not around the mounting bolt. I tightened the mounting bolt nut so the center tube is in compression and will not turn. The shackle rotates on the OD of the bushings. They work really good.
Buick455 is offline   Reply With Quote
Old 01-08-2011, 08:54 PM   #2
Pop's C-10
Pop's C-10's Avatar
Re: Greaseable rear shackles
nice mod
Pop's C-10 is offline   Reply With Quote
