Old 01-08-2011, 09:56 PM   #1
80_cutlass
Greetings
New here. Just finished installing an Olds 403 into my 79 LWB Scottsdale that once upon a time had an Olds diesel in it. The darn thing is a big ol' pile of dookie, but has a killer engine.
The 403 is built with KB pistons and a middle of the road CompCams camshaft. Should make right around 400 ft/lbs of torque.
I am reusing the th400 that it had, but am on the hunt for some 3.42 gears to replace the 2.73s that are in it now.
The interior is pretty shot and I need a dash pad and most of the guages and the panel that goes on it....but it does go vroom!
sb
80_cutlass is offline   Reply With Quote
Old 01-08-2011, 11:29 PM   #2
lilpoindexter
lilpoindexter's Avatar
Re: Greetings
lilpoindexter is offline   Reply With Quote
Old 01-09-2011, 09:47 AM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Greetings
Welcome Aboard ! X2 ^^^^^^^
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-09-2011, 02:10 PM   #4
80_cutlass
Re: Greetings
Here's some pics, not that its much to look at:
Old 01-09-2011, 02:12 PM   #5
80_cutlass
Re: Greetings
Interior:
Old 01-09-2011, 02:13 PM   #6
80_cutlass
Re: Greetings
The part that caused my dad to ask, "You put THAT engine into THAT POS?"
Old 01-09-2011, 02:43 PM   #7
mooseknuckles
mooseknuckles's Avatar
Re: Greetings
welcome! ....looks good. that's exactly how every other project started!
mooseknuckles is offline   Reply With Quote
Old 01-09-2011, 02:50 PM   #8
BigRed76
BigRed76's Avatar
Re: Greetings
Looks like a solid truck, and love the olds motor as i have a 72 cutlass myself with the 455 in it
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-09-2011, 02:55 PM   #9
80_cutlass
Re: Greetings
Thanks. It looks better in pics than it really is!
There is a lot a rust on the doors and on the floor boards, at least the corners aren't rotten. The bed is rotten on most of the floor, especially where the PO had left some rubber that trapped water.
I got it for a song at a county auction, it already had a worn out Olds 350 in it, so the "conversion" was sort of done, albeit a hack job, so I had to fix a lot as I was going. The only thing that is right is the drive line.
Basically, I guess its got a LONG way to go.
sb
Old 01-09-2011, 03:01 PM   #10
BigRed76
BigRed76's Avatar
Re: Greetings
Yeah body work seems to always be the biggest thing with these trucks.
Zach
Old 01-09-2011, 09:33 PM   #11
80_cutlass
Re: Greetings
More pics:
sb
Old 01-09-2011, 09:45 PM   #12
Pop's C-10
Pop's C-10's Avatar
Re: Greetings
welcome...my pop's had a 403 in a 70.that thing would haul
Pop's C-10 is offline   Reply With Quote
Old 01-10-2011, 06:59 AM   #13
justpball
justpball's Avatar
Re: Greetings
nice start to a cool project!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 01-13-2011, 07:34 PM   #14
80_cutlass
Re: Greetings
Thanks for the welcome(s). Will start driving it soon, switching between it and an 82 Dodge D150.
sb
