Old 01-08-2011, 09:59 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Rear axel Perches
Can you buy new ones so you don't have to cut your off to do a "flip" i got new u bolts an such just need the perches... and dont want to buy a "flip kit"
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 01-08-2011, 10:08 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Rear axel Perches
I buy them at a trailer parts place. Measure your axle tube and they can sell you a pair cheap. Figure under 20 for the pair at the most.
Old 01-08-2011, 10:09 PM   #3
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
LOL you wouldn't happen to know the diameter of Dana 70 with spicers would you?
Old 01-08-2011, 11:22 PM   #4
Mattman2010
Mattman2010's Avatar
I have a dana 70 HD which has 4 inch tubes. I think the Dana 70 uses different ones than a dana 70 hd. It shouldnt be hard to measure yours and see what they are.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 01-08-2011, 11:52 PM   #5
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
lol i just didn't want to roll around in the snow :P hahaha but sigh i guess i'll have too. lol
Old 01-08-2011, 11:59 PM   #6
Mattman2010
I think I have read that it is 3.5", but im not sure if that is right or not. I know the Corp 14 bolts are 3 inch, and the dana 70hd is 4.
Build Thread
Build Thread
Thread
Old 01-09-2011, 12:04 AM   #7
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
whats the difference between a D70 and D70HD? because mine looks rather large in diameter
Old 01-09-2011, 12:17 AM   #8
Mattman2010
Uh, bigger tubes. Thicker tubes as well. I think gross weight for the dana 70 hd was 10,000 lbs.
Build Thread
Build Thread
Thread
Old 01-09-2011, 12:20 AM   #9
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
I walked right into that one.....
Old 01-09-2011, 12:24 PM   #10
BIG V
buy them for 3.5 tubes... If they are not big enough use the victor wrench and open them up a bit. I used pads for 3 inch tubes and opened them up a bit for my dana 70 super duper heavy duty don't really care about weight spec's rear axle.... lmao
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 01-09-2011, 12:37 PM   #11
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Do you have any pics of your install?
Old 01-09-2011, 12:59 PM   #12
BIG V
here's one
