Old 01-09-2011, 12:57 AM   #1
pmpski_1
pmpski_1's Avatar
Merry Christmas to me
Yeah, a little late, but I always procrastinate a bit around the holidays.
I got the oil pressure gauge a while back from HartRod because I knew I eventually wanted to the the Auto Meter gauge cluster. I found a used gauge cluster locally for like 10 bucks or something like that, and I let them both sit in the garage for a while.
Autometer had the tach rebate this summer and I had a couple Summit Bucks burning a hole in my pocket so I collected a few more gauges.
Then I talked to board member Putter (Eric) - I'm sure you're all familiar with his work - about putting a cluster together for me. So I got the rest of the guages that I needed and sent them all of to Eric.
I love it. I probably won't install it until Spring but it looks great and it's put together really well.
I may eventually swap out the bezel for a nicer one or give this one a coat of silver where it used to be chrome around the edges. But it kinda matches my truck the way it is.
Thanks again Eric! Can't wait to get it in the truck.
pmpski_1 is offline   Reply With Quote
Old 01-09-2011, 03:14 AM   #2
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Merry Christmas to me
Looks awesome!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-09-2011, 04:15 PM   #3
Putter
More Cowbell....
Putter's Avatar
Backlit gauges. Cluster also has a hidden LED 'high-beam' indicator.
Brian,
Glad you like it. Merry-belated-Christmas! A new bezel will completely change the look of it where the plastic meets the gauge-surrounds.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 01-10-2011, 01:53 AM   #4
Ticker
Schweet!
What does the back look like?
What do you use for the turn indicators?
Ticker is offline   Reply With Quote
Old 01-10-2011, 02:27 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Putter,... What do you charge to do something like this?
Keith
Convert to disc brakes.
Old 01-10-2011, 10:59 AM   #6
Putter
More Cowbell....
Putter's Avatar
Originally Posted by Ticker View Post
Schweet!
I used the original turn signal cardboard tubes with green caps, just like the factory. I modified the bulb sockets to use wire instead of the printed circuit contacts.
I don't have rear pics, but maybe Brian can post some.
Old 01-10-2011, 11:01 AM   #7
Putter
More Cowbell....
Putter's Avatar
PM sent.
Old 01-10-2011, 01:10 PM   #8
FIREBALL
(007) aka Houdini
FIREBALL's Avatar
cool! I'm going with the same cluster idea but im going with either the black bowtie gauges with orange needles (or autometers instead)..... Do they sell a tach big enough to fit in the middle anybody know??
Live life one day at a time!
FIREBALL is offline   Reply With Quote
Old 01-10-2011, 04:50 PM   #9
19seventeeCustom
guages look great!!
19seventeeCustom is offline   Reply With Quote
Old 01-10-2011, 09:51 PM   #10
Putter
More Cowbell....
Putter's Avatar
The center hole (3-3/8") is very common for speedometers and tachs. It's the OTHER gauges that are difficult to find in the 3-3/8" size.
Old 01-10-2011, 10:43 PM   #11
Ticker
I'm kinda thinking I'll do some sort of smoked plexi cover for an F/A mixture or something...
