Old 01-09-2011, 02:49 AM   #1
ebry710
Back Seam between Cab/Roof: Seen or Filled
I am preparing to paint the cab roof of my 71'. There is a seam to the back of the roof panel. I am planning to seal it with seam sealer. Do I try to make the seam invisible or do I keep the line?
1971 Chevy C-20 Flatbed SBC350/Turbo 350
"Torque Is Controlled Power"
ebry710 is offline   Reply With Quote
Old 01-09-2011, 02:54 AM   #2
71sierragrande
Petroleum User
71sierragrande's Avatar
Re: Back Seam between Cab/Roof: Seen or Filled
I would say leave it as is, but you could weld the seam and grind it smoothe also. Spot weld to avoid warping if you go that route.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 01-09-2011, 12:55 PM   #3
71 super
71 super's Avatar
originally the seam was visable. It is up to you as to what to do, and in my opinion it depends on what your truck is- if original resto, leave it as it was, if a shaved custom get rid of it.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 01-09-2011, 02:33 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
It depends on what kind of sealer it is. If it gets hard it will crack. The previous owner of my White '67 filled the seam with body filler without welding it and it cracked and pieces started falling out. I just dug it all out and left the seam visible.
LockDoc
Leon
