Gas tank and lowered blazer...
Those of you who have airbagged or are running a large drop, what have you done with the gas tank? Does it hang really low, or hit the ground? Is there a slimmer alternative?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
Future TOTM Winner
Re: Gas tank and lowered blazer...
I haven't bagged a truck, and I'm not sure if the factory tank will drag...but if I'm not mistaken it is 17 inches from top to bottom. Mrhino had installed one of these tanks here at this thread (see post #28 through #40). It seemed to fit in his truck real nice and looks like it might save you about a few inches of depth if you end up needing to.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 01-09-2011 at 12:47 PM. |
I saw that, looks good just not too sure about the notch in the frame for the hose....
Future TOTM Winner
Well...how about a 25 gallon (NOT the 31 gallon) tank from a 73+ blazer. They fit back there perfectly and are less than 11 in tall. It is helpful if you cut and rotate the filler tube but not 100% necessary. Basically you would swivel it to make it point the other direction.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 01-09-2011 at 02:26 PM. |
great because i was planning on putting in a flush gas cap anyways...
anyone use any other gas tank?
I'm in the same boat, anyone?
stock tank...about a 4" notch
![]() Join Date: Nov 2007
I also have a stock tank, but with a bolt in c notch.
![]() Join Date: Apr 2004
stock tank on mine.
![]() I put the air tanks and valves inside. ![]()
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
can any of you take a pic from the rear showing how low the tank hangs please...so jealous of your rides....
What about a fuel cell from Dave Boyd or Fuelcellguy? You can get it made as high and tight as you want/need.
Posted via Mobile Device |
#13 | |
i live in Canada. Getting stuff across border is murder.
#14 |
Mark (Fuelcellguy) is having a pretty nice sale right now. It might offset a lot of the shipping cost. Check the Vendor section.
#15 |
A couple of pics aired out, about 4 1/2" from the ground.
#16 |
"Trucks with Class"
![]() Join Date: Jul 2000
Fuel Cell Guy-Mark, has done several for me.
They fit nice with no cutting or mods to stock filler, etc. They look so nice compared to stock or plastic. Warning: They make you want to do more things under there like new exhaust, big vette rams, smooth filler cap and...and...and. Last edited by PICKMUP; 02-27-2011 at 09:03 PM. |
