01-09-2011, 01:55 PM | #1 |
Whats this stuff called?
While taking apart my blazer i noticed a lot of rubber gasket ? type of stuff. It seemed to be in between the back floor and the wheel wells, and in between the floor to the cab portion of tub (the floor sits on top of the cab portion). It's some kind of rubber seal. I ask be\cause it actually worked at keeping out moisture. I have no rust in these areas. Is this something that should be replaced?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
01-09-2011, 02:08 PM | #2 |
Re: Whats this stuff called?
Most likely what you are refering to is "seam sealer"...
Search the auto body section and get the experts opinions. Posted via Mobile Device
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
01-09-2011, 02:56 PM | #3 |
Truck and auto performance nut
that would be my guess too.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
01-10-2011, 01:41 AM | #4 |
If it's like mine, the underside is wavy to match the bed, and the top side is flat. Without it no more flat floor in back.
