Old 01-09-2011, 03:10 PM   #1
k1rodeoboater
Door wont open from the inside...any ideas?
My drivers side door will not open from the inside. I have to roll down the window and open it from the outside to get out of the truck which is kinda annoying. I've taken the door panel off to try to get a better look at what's going on with the latch mechanism and all I can tell is that it needs to move just a hair more to release I believe. Is there any way to adjust the linkage?
k1rodeoboater is offline   Reply With Quote
Old 01-09-2011, 03:29 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Door wont open from the inside...any ideas?
You should be able to loosen the 3 screws that hold the remote control assembly (the part the inside door handle attaches to) and rotate the mount on the door to provide the travel needed.
Old 01-09-2011, 10:02 PM   #3
k1rodeoboater
tried that...no joy. It still won't open from the inside. I have a NOS door latch that I can install, but I want to try everything else first.
Old 01-10-2011, 08:48 PM   #4
k1rodeoboater
Any more ideas? I don't have to work tomorrow so I want to do a few things on my truck
Old 01-10-2011, 09:18 PM   #5
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
The guy we got my daughters truck from, drove it for 7-8 years with the same problem. I was looking in the door, right after we got the truck, I noticed one of the springs were off back inside the door by the outside handle. I clipped the spring back on, and it is working now. The spring behind the inner handle is broken also on hers, but it is still working for now.
Good luck!!!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 01-10-2011, 09:20 PM   #6
onequickchevy
onequickchevy's Avatar
If you take out the three screws and pull on the flat rod does the door open? If not, it is possible the latch is worn and there is major slop inside. Sometimes parts that are supposed to line up don't after alot of use.
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
