Old 01-09-2011, 03:45 PM   #1
bigblocksean
4x4 conversion??
Greetings all, Iam seeking some advice about a project Iam planning, I have a very solid, clean 70 Custom Camper 20 2wd, Iam wanting to convert it to 4x4 and have an 85 3/4 ton 4x4 frame and running gear, My question is would it be easier to convert the 70 frame to 4x4 (have a blazer complete 4x4 frame as well) or do a body swap onto the 85 frame? I have done many lwb to swb conversions on 2wd trucks, and am a welder by trade, your thoughts?? thanks
bigblocksean is offline   Reply With Quote
Old 01-09-2011, 05:21 PM   #2
Maxxd07
Maxxd07's Avatar
Re: 4x4 conversion??
It would depend on the condition of the frames of course but if it was me I would swap the 4x4 stuff onto the existing frame. Dieselwrencher has a nice write up in his build thread. He is converting a longhorn into a 4x4, this is the thread.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 01-10-2011, 01:10 AM   #3
KrazyRay
KrazyRay's Avatar
The square body wheel base is about 4" longer than the 67-72. I think it would be easier to take the front spring mounts off the square body and use them on your 70 frame.
KrazyRay is offline   Reply With Quote
Old 01-10-2011, 09:04 AM   #4
duallyjams
duallyjams's Avatar
If your 70 is a leaf spring rear the convert it.If it is a coil spring rear then the frame is different. You are welder you can take the blazer frame and the 70 frame and make one.To use the 85 requires a body lift and moving spring mounts to center the wheels this would be the harder route.You can do a search as this has been covered many times.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-10-2011, 07:39 PM   #5
bigblocksean
thanks for the info fellas, think i will use the 72 blazer hangers and members, kinda hate to tear into it it rides so good now..oh well just want a 4x4!
Old 01-11-2011, 02:44 PM   #6
msgross
msgross's Avatar
You might be able to find a 72 4x4 with crappy body and good running gear. I bet you could pick that up for under $500, clean them up and swap your body and engine over...
diy4x.com (and our parts board) has spring hangers for you..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-11-2011, 08:00 PM   #7
bigblocksean
Sweet I just scored a 72 K-20 on craigslist for 600 bucks and i drove it home lol, let the body swap begin!!!
Old 01-11-2011, 11:26 PM   #8
msgross
msgross's Avatar
perfect... disc brakes, power steering and strong drivetrain...
The Garage:
