Old 01-09-2011, 04:52 PM   #1
kSStamp0182
LSX addict
kSStamp0182's Avatar
'82 6.0 swap HEDDER/MANIFOLD question
after much searching and confusion, i still have no idea who or where makes a LT hedder that will DEFINITELY fit my project. can someone please point me in the correct direction? also, i have F-body manifolds from an 01 SS i used to own. does anyone have confirmation that these will fit? if so i will just use them until a definite fitting hedder is released.
kSStamp0182 is offline   Reply With Quote
Old 01-09-2011, 06:49 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: '82 6.0 swap HEDDER/MANIFOLD question
I dont have a square but I am told that Doug Thorely has LT header for your truck with the LS, also I have been told the TBSS manifolds work weel where you need them tucked close to the motor like block hugger shortie headers.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-09-2011, 07:16 PM   #3
85burb
85burb's Avatar
Dougs last time i checked does not have any. S&P sells some for close to 600 for shorties. I am going to try 98-02 f body headers. There is a person on here that has them installed. Think he had to slightly modify his controll arm or something.
http://67-72chevytrucks.com/vboard/s...d.php?t=411567
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 01-10-2011, 12:58 PM   #4
kSStamp0182
LSX addict
yeah all i could find from dougs was for earlier models. thanks for the info tho, lemme know how the fbodies go. im gonna try the fbod manifolds, they definitely hug the block better than the lq4s. we'll see how it goes.
Old 01-10-2011, 01:55 PM   #5
Clyde65
Clyde65's Avatar
I used Sanderson Headers on my swap, I like them but they are shorties and you might not want those, give them a call and see if they can help you.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-11-2011, 11:07 AM   #6
olblue81
olblue81's Avatar
These are the only ones I've found. They are made by Heddman and are a bit pricey but like I said, they are the only ones I've found.
http://www.brphotrods.com/mm5/mercha...ory_Code=CNV10
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
Old 01-11-2011, 11:14 AM   #7
kSStamp0182
LSX addict
alright! i remember they had them in the works forgot about them tho! thanks alot
73-87, fbody manifolds, lq4 hedder, ls swap hedder, lsx hedder
