'64 GMC Steering Wheel Diagram?
When I pulled the steering wheel off last weekend a small, split, cylindrical bushing feel out of the back of the wheel as I was about to lay the wheel down on the truck seat. Does this bushing go inside the opening on the back side of the wheel? Or do I slip it down on the column shaft? It seems like it may come into contact with the horn contact ring and possibly distort the ring and/or the upper column bushing as I torque down the wheel upon re-install. One end of this bushing is tapered. Taper up or taper down when re-installed? I'll go out and take an image or two of this bushing. An original assembly diagram would be appreciated. Thanks in advance.
Re: '64 GMC Steering Wheel Diagram?
Here is an image of the bushing. Notice the tapered end.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I believe that is the turn signal canceling cam.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Methinks the canceling cam is black plastic and still screwed to the back of the wheel. This piece is thin metal.
at
