Old 01-09-2011, 05:23 PM   #1
mrsmothers
brake problems
Well I got my truck back from the shop it runs but dosent stop. It had been sitting since 06 and well it has no brakes I just replaced the master cyl but still no brakes. I havent found any leaks in the system next but I am not getting any pressure on the brake peddle. What should I do next?
mrsmothers is offline   Reply With Quote
Old 01-09-2011, 06:37 PM   #2
JimKshortstep4x4
Re: brake problems
Did you bench bleed the MC and bleed the wheel cylinders?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-10-2011, 03:09 PM   #3
mrsmothers
Re: brake problems
I didnt bench beed the master cyl and havent got a chance to bleed the lines we had a cold front come in everything is frozen. I didnt know you had to bleed the mc can you do it with it on the truck or do I have to take it off ?
Old 01-10-2011, 03:22 PM   #4
clear
Re: brake problems
I am in the process of replacing my booster and MC on my truck. Every thing I have read says bench bleed before installation. Here is in interesting article. http://www.superchevy.com/technical/...nch/index.html
clear is offline   Reply With Quote
Old 01-10-2011, 11:02 PM   #5
Murphy IRE
Re: brake problems
There is a kit that comes with some MC or they can be purchased. It allows you to bleed the MC in place. I just did it on mine. The plug has a small nipple for attaching tubing. Route the tubing back into each compartment. I used binder clips to keep the tubing in place. Pump slowly and it will cycle the air out. It was really easy. Then I started to bleed the lines by pumping, but switched over to gravity bleed (one man show).
Murphy IRE is offline   Reply With Quote
