Dana 44 - Broken Spider Gear
I was starting to do a rebuild on my dana 44 front axle, and decided to pull the diff cover before i started to get to far into doing the rebuild. I found that the drivers side spider gear had teeth that where broken off, and several that where cracked.
How hard is it to replace spider gears? I know people say do not attempt to change gear ratios in a axle if it is your first time because it is a hard thing to do. So I am trying to figure out if I want to replace the spider gears, or just spend the money on a different dana 44. ![]() ![]() ![]() Thanks, Matt
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
| Bookmarks |
